wattsy Posted February 6, 2015 Share #61 Posted February 6, 2015 Advertisement (gone after registration) Tim is fairly active over at the getdpi forum. Link to post Share on other sites More sharing options...
Advertisement Posted February 6, 2015 Posted February 6, 2015 Hi wattsy, Take a look here Tim Ashley - 35mm FLE review . I'm sure you'll find what you were looking for!
moomooranch Posted February 6, 2015 Share #62 Posted February 6, 2015 Hmm, this result doesn't seem to be all that surprising given the MTFs of the 35mm 'lux ASPH: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Full spec sheet: http://leica-camera.pl/files/2011/02/New-Summilux-M-35-mm-ASPH-Technical-Data_en.pdf MTF of the RX1's Sonnar: This is one of the reasons I went with the pre-ASPH 35 'lux instead, given that I shoot most often at f/8: the pre-ASPH appears to have similar sharpness/field flatness (perhaps even better than the pre-FLE version, except for the extreme corners), but with less distortion at this setting. Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! Full spec sheet: http://leica-camera.pl/files/2011/02/New-Summilux-M-35-mm-ASPH-Technical-Data_en.pdf MTF of the RX1's Sonnar: This is one of the reasons I went with the pre-ASPH 35 'lux instead, given that I shoot most often at f/8: the pre-ASPH appears to have similar sharpness/field flatness (perhaps even better than the pre-FLE version, except for the extreme corners), but with less distortion at this setting. ' data-webShareUrl='https://www.l-camera-forum.com/topic/202466-tim-ashley-35mm-fle-review/?do=findComment&comment=2760331'>More sharing options...
lct Posted February 6, 2015 Share #63 Posted February 6, 2015 The Summilux 3.5/1.4 pre-asph does show some focus shift depending upon the calibration. My sample is set to be accurate at f/2.8 for instance and back focus a bit at f/1.4 and f/2. On the contrary, a well calibrated 35/1.4 FLE like mine does not exhibit the least focus shift at any aperture, on 3-D subject matters at least. I won't bore you with my sample pics but they are pretty obvious. Link to post Share on other sites More sharing options...
