M focus peaking , preview not working
cirke
  • Replies 47
  • Created
  • Last Reply
I wish I had my M...:(. I have a strong suspicion that I will prefer subtle. It will probably work best on long lenses where I will use it I rather fail to see the sense of using it on a 50 mm lens when there is a perfectly good rangefinder provided. (well, maybe the Noctilux, but then I have heard it is fine with such shallow dof.)
I wish I had my M...:(. I have a strong suspicion that I will prefer subtle. It will probably work best on long lenses where I will use it. I rather fail to see the sense of using it on a 50 mm lens when there is a perfectly good rangefinder provided. (well, maybe the Noctilux, but then I have heard it is fine with such shallow dof.)
I shoot with the summilux 35 mm on the NEX 6 only with focus peaking it is faster and better than the rangefinder for me
I wonder why you want to change your M9 for a M if you want o use only the rangefinder
:confused: Because it is primarily a rangefinder... The add-ons are for use in cases that a rangefinder is out of its depth. If I would want to focus through the lens as main option I would get a camera which was designed for that purpose, like an EVIL or DSLR.
the focus peaking on my M work only if subject has strong contrast....if not bye bye
also after it show you the red lines (very small not easy to see !) they disappear and you must to re-focus to see again
anyway not so useful
Nice not to feel alone
I agree it seems nearly useless
and what about the level ? can you get it in the viewer and LCD or does it keep always hidden in the menu ?
it works but difficult to use at x1, ot only with very high contrast
Jaap I dont understand RTM, is it something like OMF ? only my fault ? :-)
Read The Manual (Jaap's a nice guy and doesn't use the more blunt RTFM)...
Glad you've got it sorted out. In my experience (with wide and long glass) the key issue is scene contra. I find x10 works best with wide glass and x1 or x5 is more useful with long lenses...
Read The F.... Manual :)
Seems to me that the user interface is getting more and more complicated with all these new 'features' of the new M, the simplicity if the M8u user interface is one of the things I enjoy with my camera... seems less and less likely I will buy the new M
and for me seems more and more I'll buy a Sony :)
thanks
and the level can you get it in the viewer when shooting ?
Erick
I believe Sony is on record saying a FF NEX is not a feasible product, so you may be waiting for a while:( This is Leica's first attempt at focus peaking (whereas Sony's had a few generations of cameras to perfect it), so there will be hiccups. Time will tell if Leica can or will address issues with firmware.
Have you considered the Ricoh GXR with the M mount module? It seems that that camera/setup maybe better suited for what you're looking for than the Leica M. The sensor in the module is APS-C size, but it is specifically calibrated for use with rangefinder lenses (whereas the NEX cameras are not).
PS I doubt that the level can be displayed/projected in the M's viewfinder.
Erick
Have you considered the Ricoh GXR with the M mount module? It seems that that camera maybe better suited for what you're looking for than the Leica M. The sensor in the module is a APS-C size, but it is specifically calibrated for use with rangefinder lenses (whereas the NEX cameras are not).
the sony nex 6 works very well and I shall not buy anymore an APS-C sensor , I'll keep of course the M and I shall see what will come
I really like the way it was implemented on the Ricoh GXR where you can set it to 'grey' mode where it shows up the areas that are n focus in a sort of silhouette (a little hard to explain) but would be nice if it could be implemented in a firmware upgrade
