jdlaing Posted March 17, 2013 Share #1 Â Posted March 17, 2013 Advertisement (gone after registration) What frame lines does the MATE pull up on the M9? Link to post Share on other sites More sharing options...
Advertisement Posted March 17, 2013 Posted March 17, 2013 Hi jdlaing, Take a look here MATE frame lines.... I'm sure you'll find what you were looking for!
01af Posted March 17, 2013 Share #2  Posted March 17, 2013 The Tri-Elmar-M 28-35-50 mm Asph (a.k.a. medium-angle Tri-Elmar, or MATE) automatically pulls up the frame lines matching the respective focal length setting—i. e. 28/90 for 28 mm, 35/135 for 35 mm, and 50/75 for 50 mm. Link to post Share on other sites More sharing options...
jdlaing Posted March 17, 2013 Author Share #3  Posted March 17, 2013 The Tri-Elmar-M 28-35-50 mm Asph (a.k.a. medium-angle Tri-Elmar, or MATE) automatically pulls up the frame lines matching the respective focal length setting—i. e. 28/90 for 28 mm, 35/135 for 35 mm, and 50/75 for 50 mm.  Beautiful. Thank you.  I am considering one of these as I do 50/35 most of the time.  My plan: I have a WATE, 50 Summilux, 90 Summarit, 28 Elmarit, 35 1.4 Voigtlander.  I'll keep the 50 Lux, 35/1.4, WATE, 90 and add the MATE.  I don't do a lot of low light so the f4 should be fine at the low end. And I'll have the 50 and 35/1.4's to work with the occasional low light. The reason I asked about the frame lines was to avoid the Frankenfinder on the camera ALL the time. I use it with the WATE but it is cumbersome.......  Fair plan? Link to post Share on other sites More sharing options...
01af Posted March 17, 2013 Share #4 Â Posted March 17, 2013 Fair plan? Basically ... yes. Provided you can live with a slightly reduced image quality at 28 mm, as the Tri-Elmar, at 28 mm, is pretty good but not quite as good as an Elmarit. But I'm not saying this to scare you, as the Tri-Elmar's performance at 28 mm definitely is not bad and more than good enough for most applications ... unless 28 mm was your most-important and most-used focal length. I feel it's a good plan. Maybe you want to keep your 28 mm Elmarit for a while after having acquired a Tri-Elmar, until you're really sure it's fine for you to let it go. Â The only problem is ... the Tri-Elmar-M 28-35-50 mm Asph has become a sought-after lens; it is hard to find in the used market these days, and mint or near-mint samples are calling increasing prices. Link to post Share on other sites More sharing options...
Einst_Stein Posted March 17, 2013 Share #5  Posted March 17, 2013 Beautiful. Thank you. I am considering one of these as I do 50/35 most of the time.  My plan: I have a WATE, 50 Summilux, 90 Summarit, 28 Elmarit, 35 1.4 Voigtlander.  I'll keep the 50 Lux, 35/1.4, WATE, 90 and add the MATE.  I don't do a lot of low light so the f4 should be fine at the low end. And I'll have the 50 and 35/1.4's to work with the occasional low light. The reason I asked about the frame lines was to avoid the Frankenfinder on the camera ALL the time. I use it with the WATE but it is cumbersome.......  Fair plan?  You don't need extra view finder with MATE. It will switch to the right one.  I don't have any LUX, I have Summicron. Compared to other lenses, including MATE, the f2 does not mean speed but means image rendering. Even under good lighting I found being able to switch between f2 and f8 is much more important to me than the convenience of quickly switching the focal length. I found MATE hardly justified to loose the sweetness of Summicrons.  Your milage may vary. Link to post Share on other sites More sharing options...
wosim Posted March 17, 2013 Share #6  Posted March 17, 2013 I'll keep the 50 Lux, 35/1.4, WATE, 90 and add the MATE.  I don't do a lot of low light so the f4 should be fine at the low end. And I'll have the 50 and 35/1.4's to work with the occasional low light. The reason I asked about the frame lines was to avoid the Frankenfinder on the camera ALL the time. I use it with the WATE but it is cumbersome.......  Fair plan?  It is more or less the same set-up I use: WATE MATE Voigtländer Nokton 1.4 40mm (I really love this tiny, tack sharp lens) Summilux-M 1.4 50mm Asph. Tele-Elmarit-M 2.8 90mm  For me it is perfect (the Voigtländer Ultron 1.9 28mm, the heavy Summilux-M 2.0 90mm pre-Asph. and the Tele-Elmar 4.0 135mm I only use occasionally). Link to post Share on other sites More sharing options...
jdlaing Posted March 24, 2013 Author Share #7 Â Posted March 24, 2013 Advertisement (gone after registration) I got it. I've used it and its great! Link to post Share on other sites More sharing options...
