lens wide open best
kb7001
Because Leica M film bodies and Leica M digital bodies don't have different flange distances, as simple as that. The guys at popflash.photo just made this story up.
By the way—if there really was a difference of 0.04 mm in the flange distances then a 50 mm lens would miss the intended focus distance of 0.9 m by 9.3 mm, not 2 cm.
Thanks.
Nevertheless, upon emailing Zeiss and discussing this they were more than happy to take the lens back for adjustment. So what did they do to improve it?
Mark
  • Replies 41
  • Created
  • Last Reply
The C Sonnar 50 mm 1:1.5 ZM has some aperture-related focus shift. Usually it's adjusted for optimal focus at f/2.8 so at wider apertures, it will front-focus slightly; at smaller apertures, back-focus slightly. Upon customer's request, they will re-adjust it so it will focus perfectly at full aperture, back-focus slightly at f/2.8, and back-focus more at smaller apertures. For lens testers and pixel peepers, the re-adjustment may look like an improvement but for actual use the original set-up usually is better.
