ftb Posted February 2, 2013 Share #1 Posted February 2, 2013 Advertisement (gone after registration) Hello everyone, I have a ASA light blinking for 16 seconds or so each time i press the release button. I assumed that the asa is not correctly set...but it is.... I am not sure what to do. Did you ever have this problem? Thank you very much in advance for your help. greetings. m. Quote Link to post Share on other sites More sharing options...
Advertisement Posted February 2, 2013 Posted February 2, 2013 Hi ftb, Take a look here ASA light blinking problem. I'm sure you'll find what you were looking for!
Guest Randle P. McMurphy Posted February 4, 2013 Share #2 Posted February 4, 2013 (edited) Please Read The Fucking Manual: If the camera electronics detect an incorrect setting, the following display flashes to warn you: For example, if the dial is set to "DX” but no DX-coded film is loaded or a film with damaged or unread- able identification, "100” flashes as an indication that the exposure control is assuming a film speed of ISO 100/21°. By contrast, if the dial is set to an invalid position between "DX” and the manual val- ues, "ASA” flashes for the entire display duration of 16 s, i.e. the exposure metering is not displayed. In this case, exposure is once again as for ISO 100/21°. The table on the next page lists the different operating statuses in detail........ http://www.google.de/url?sa=t&rct=j&q=asa%20blinkt%20bei%20leica%20m6&source=web&cd=3&ved=0CEkQFjAC&url=http%3A%2F%2Fen.leica-camera.com%2Fassets%2Ffile%2Fdownload.php%3Ffilename%3Dfile_1738.pdf&ei=66MPUeTSHe_74QTrhYHgCg&usg=AFQjCNFKMIXZ8fFeIEjBhtc-WPhYHNgMlQ&bvm=bv.41867550,d.bGE&cad=rja Edited February 4, 2013 by Randle P. McMurphy Quote Link to post Share on other sites More sharing options...
