Elmarit 28mm f2.8 II
BW-NH
Good morning-
I am new to this forum- I have just purchased a used M9 to start creating digital images.
None of my lenses have 6-bit coding on them. Does the manual coding of the lens as it is mounted onto the camera matter? Is it merely adding information to the exif data?
I have been using an M6 for many years, and currently have 4 lenses- 28, 35, 90 and 135. My 28mm f2.8 is apparently a series II- and I am not sure what to "code" the lens as. Should I manually enter the code as a series III (1804) or as a series IV (1809)? Does it matter?
Also- I am thinking of acquiring a 21mm f4 Voigtlander (it is affordable)- and wonder if there is consensus as to the proper code for that? (assuming that coding the body-to-lens matters.) http://www.l-camera-forum.com/leica-news/leica-lens-codes/ seems to state the code should be as a 21mm ASPH... but I have read other places that the 6-bit code for that lens should be "1", which seems to correspond to the 21mm non-ASPH lens. Again... does it matter?
Sincerely,
Bob W from New Hampshire
Hi,
First of all welcome to the forum, and congratulations with the purchase of your M9.
For focal lengths up to 50 mm the corrections really matter on digital M camera's. Higher than 40mm can be used without it, without too much trouble.
Coding corrects CA and light fall off for all lenses. On the M8 this is the only option you have to activate it. With the M9 you can also choose the current lens in a menu to activate the same benefits.
So for M9 users with one lens only it is not necessary. If you switch lenses often the hardware coding of the lens is only a conveniance.
Good morning-
Dirk, thank you for the reply. I appreciate the welcome, and the knowledge.
What "code" do you think I should use for my Elmarit 28mm f2.8 which is apparently a series II, and therefore, not listed? Should I just try all of the other possible 28mm settings and settle on the one that seems to work best?
I do swap lenses frequently while shooting, and so do want to look into whatever I can do to code the lenses- starting with black marker. My 90 and 135 look like they are candidates for a replacement pre-grooved flange, as their flanges are held on by 6 screws. However the flanges of my 28 and 35 do not attach the same way. I may attack them with a dremel after marker-ing them.
Tom_b, thank you for the suggestion and opinion regarding the 21mm.
Bob
Here is a photo of my 21/2.8 in which Leica installed the 6 bit code on it. Suggest you use that code.
Hi Bob,
Where do you live? Have a look at the leica technicians sticky...
All my lenses were coded by Will van Manen
Coding a lens professionally will costs about 60 euro, and he will make sure the lens is coded with the correct code.
Until now the coding was always an option on top of a CLA. Do not know if it can be done without. DIY is no option for me as I get cold sweat when a dremel comes near my beloved lenses :) Any small chip of metal that gets stuck in the wrong spot can do a lot of damage...
  • 1 month later...
Good afternoon!
I thought I would report back.
Today I pulled out my paper-template, marker-ed each lens with black Sharpie, tested, masked with plastic-wrap and masking tape, and then "Dremeled" out grooves into each lens, removing only the black ink. I worked slowly and carefully, and succeeded with all 5 lenses. THe 21 f4 Voigtlander is coded as a 21mm f2.8,
I only grooved the black spots- I couldn't think of a good reason to take out any more metal than necessary.
The m-9 correctly detects each lens with black ink in the grooves- I will clean that out, and go get some black nail polish for the final more-permanent "blackening".
I appreciate all of the earlier advice, suggestions and posting-of-image- it all helped!
Sincerely,
Bob W, New Hampshire USA
