SD-Sunny side up...
jaapv
Playing around at UV and IR with Vivek, we slipped a Nikon flash onto the M8 to get some more IR - Flash flashed-camera clicked - red light didn't stop flashing - pulled the battery. SD card full, refused to be formatted. Put it into the RD1 same story. M8, with another card just fine.:confused: :confused: :confused:
I can just hear the Leica support "You put a Nikon flash on the M8?"
It DID function, more or less. But it is interesting that it is possible to fry an SD card through using an inappropriate flash.
I had a similar SD card experience (no flash involved) after simply removing the card and offloading images with a card reader. After putting it back into the M8, the camera reported that the card was full; format attempt failed (red light flashed for 4 or 5 minutes). I had to remove the bottom plate and battery to power off. Went through this several times with same results. Returning to card reader would show images intact. Suddenly, all was fine and I was able to format the card. I don't know if this helps, but the card itself was fine (and has been ever since). BTW, card is SanDisk Ultra II 2GB.
I shot for an evening with an Olympus flash. Didn't fry anything or have any other troubles. Had to use manual settings, but from what I have read about the M8's flash automation, that was probably a better choice. So I also don't think flash was the source of the problem.
scott
Jaap, My sincere apologies. I will try and make up for it.
The Nikon flashes can be used with/without chords. I forgot to mask couple of the contacts (that does TTL) before I gave it to Jaap. A single point contact to trigger the flash should be alright (at least with my Epson R-D1s it works without any problems).
Just too excited doing infrared shots. I am very relieved that the camera is fine. Jaap you are a big man with a bigger heart!
Jaap, I am still waiting for your take your take on the UV shots.
Here is a crop of Jaap's shot (taken with my Epson R-D1s) while the M8 was being tested for UV captures.
Don't worry, Vivek, I managed to recover the shots on the card. I probably put the card itself in my box of CF cards, as I don't like using dodgy memory.Anyway, I was the one who slipped the cable onto the M8 and pressed the shutter. I'll play with the UV files I have here. I received yours and they are impressive....
