Iso newbie question
Kugelfest
In these matters, a little skepticism is valuable. Your personal film speed should be whatever it takes to produce excellent shadow detail (there are more technical measures that you probably don't need). If you don't get good shadow detail, your personal film speed is too high.
Development time guidelines are just that - guidelines. If your negatives are too flat or too contrasty, adjust the development time up or down (try 15% increments), until you get good shadow detail (i.e. your correct ASA) and good contrast (detail in your highlights).
You can't avoid looking at your negatives and applying the thought process. No table or spec sheet is a substitute. Do it once, and that is it forever for that film and developer. Then keep repeating the procedure like an algorithm.
Then you think about making pictures which is much more challenging.
