Leica M9 and Apple Lightning usb adapter
LocalHero1953
Has anyone used the new Apple Lighning usb camera adapter with a M9?
It looks as if there should be no problems, but I see some early reports of difficulties with some cameras, giving the error message USB DEVICE REQUIRES TOO MUCH POWER.
Thanks for any advice before I splash out on a ipad 4.
I do not have that particular adaptor, but when I plugged the USB connection of my newly arrived iPad Mini into my PC, the iPad showed 'not charging'. Same when plugged into my laptop. It seems that the iPad takes more than a USB port can handle and PC-wise, one needs a 2 into 1 adaptor so that two USB ports can be used for charging.
  • 1 month later...
For the record.......
I bought a new iPad and apple camera connection kit (a simple cable with a Lightning connector and a female usb connector, for which you pay £25) and have had no problem connecting it to my M9 USB cable). On connection, a download screen opens on the iPad allowing you to select the files for downloading from the m9. Downloading is reasonably quick.
None of the standard software on the iPad will ready .dng files, though you get to see the jpg thumbnail. However, a free app, PhotoRaw Lite converts and displays them, can make some simple adjustments and save as a jpg.
Transferring files from the iPad to a pc is not simple - iTunes can sync them, but uploading to Dropbox is very slow. I only want to use the iPad to display the raw images after taking them, to show to portrait subjects, and to check quality etc, and for these purposes it works very well. Later I can download directly from the m9 to Lightroom on a pc.
Interesting. I had read previously that the iPad is hopelessly slow at dealing with raw files. How are you finding the conversion process time-wise?
As to the adapter, am undecided whether the card-reader one might be a better choice than the usb one, on the basis that I would not need to take extra cables when I travel (as in the camera-specific cables).
I've just done a test. Downloading 1 image took a couple of seconds. Conversion in PhotoRaw took about 12 secs. The Lite version will only convert and show one image at a time. I think the paid-for version can handle multiple images, so i am likely to upgrade.
The iPad 4 has a new processor and reviews talk about it doubling the speed over previous iPads but I have no experience to compare.
Bob: I'm sure there are other and better methods of getting images from an iPad to a pc/mac - I only tried the Dropbox route - not to be repeated.
While it's never fast, PhotoRaw works significantly faster if you close down as many other apps as possible ( double click the home button then kill each inactive app ) as once opened apps use some of the limited RAM memory even when suspended. Once RAM runs low PhotoRaw uses the SSD as a virtual disk - which makes it agonizingly slow.
I'm using an iPad2 - the 4 may be faster and have more RAM.
  • 11 months later...
