SUPPLEMENTARY WEB SURVEY - M8 battery and SD card usage
Dear LUF members,
Following suggestions from a number of you I'm putting up a supplementary survey of our use of M8 batteries and SD cards. We hope this information will help Leica narrow down some of the issues.
I've deliberately kept the survey very short. If you have more extensive comments that you wish to make regarding M8 design or other features, please add these to the main M8 experience survey.
To complete the survey, visit: Leica M8 - battery experience
Best
x
Where do I find battery serial numbers? The only number I find on all three of my batteries is 14464.
Thanks,
Mitchell
They are REALLY hard to see. They're on the end of the small piece that has the battery contacts, at the end opposite from the contacts. I used a flashlight at an angle to make the letters more visible.
How have you marked or color-coded your batteries so you can tell them apart in the field?
(I don't want to introduce anything foreign that might harm either the battery or the camera but I do need a handy indicator so I can quickly tell them apart.)
-g
And on the original that came with my M8 (Nov 06), there is NO NUMBER at all. I thought I might have worn it off, but there is no number or remnant of a number on that one. On my spare, there is a number, and yes, it does require a bit of work to see and read :o
LJ
TO CHRIS TRIBBLE:
Chris, filled the survey & thanks for your work on the diffferent surveys.Sometimes work like this can go without acknowledgement!
On another note I posted v_1.092 develop presets for Lightroom recently & I know you wanted to post then to your lightoom preset site. They are again @ the same ftp site(I removed the older ones): ftp.fjmaresphoto.com
http://www.leica-camera-user.com/digital-forum/19346-lightrooom-develop-presets-m8-v_1-092-a.html?highlight=lightroom+presets
-g
I put a numbered sticker on the base. I also write down the date I first charged the battery. Don't know why, just keep doing it.
TO CHRIS TRIBBLE:
Francisco - thanks for the kind words + the link.
I'll add these to the site.
It's great that people like you are willing to share.
Best
Francisco's Lightroom Presets can now be downloaded from:
M8 Lightroom Presets
They're in the IR CUT FILTER NOT PRESENT set.
