M9 Banding and noise issues are gone!
Paul J
Is there software that can compare the data written to two or more cards, after transfer to the computer, to see if that data is the same?
That way one could narrow down the problem to a specific camera, card, or card reader.
Calculate CRC32 checksums with cksum - Mac OS X Hints
x
  • Replies 113
  • Created
  • Last Reply
(fps) etc.
Hmmm...you just reminded me. The problem was worse on a series of shots either in C mode or a series in normal mode. The banding would get progressively worse in the series particularly when i had hit the buffer and it was writing whilst shooting.
To me it tends to be power related and the card is clearly a determining factor.
Also, if the data transfer is the matter for the banding, this means the error in the data transfer occurs in a periodic manner. Otherwise the wrong data should more result in random artifacts and pixels/color information at the wrong position?!
I am sure Leica does not do a lot of checks if the data written to the SD card is valid. And the same as in the buffer... Normally they should check if the file is the same and if not send the data again. But maybe they did not implement such a feature because of power or CPU processing limitations.
Oh...you mean like this?
That one only turned up once.
Go figure.
All I know is my problems are GONE. I would have never thought cards could be so problematic. But I hear the same things with all systems. Just good to know that you can eliminate a concern in your life. I really thought I had a dud camera or it what some reported, as a feature of the M9. It's not true at all. If you have a problem try changing cards.
How would this make sense?
First, thank you Paul!
Rick, most cards are susceptible to physical corruption. Stuff happens. Part of the card is a complex computer circuit that talks to the camera to confirm proper writes to the card. Some card manufacturers don't follow the standards to permit such checks, and some camera makers do not write their firmware code to use the check-codes, or they simply ignore errors. Such happens all the time in the computer biz.
it is weird- I use the cheapest cards that I get off the counter at my post office. I never have an issue with these cards... I only use 4 and 8 gig cards that cost 11$ or so...
the only times I have had weird sensor/noise/banding issues has been when the battery is about to die...
I don't think the body writes different to each different card. I think the cards record differently based on the quality of the card.
I understand the distinction but I don't understand how the card influences the actual data (other than instances where it is obviously corrupted – bits missing, etc.). Doesn't the camera just feed the card a bunch of 0s and1s? If the camera recorded to analogue tape I could understand that the interface and/or tape mechanism might introduce additional noise but to a solid state memory card via a digital interface?:confused:
Thinking about this more surely the banding noise has to be created upstream of the buffer – somewhere in the analogue to digital conversion. It seems a bit like voodoo blaming it on the card.
It would be interesting to see if the problem still persists with the latest firmware that supposedly has better power management, IIRC?
Thanks. I figured there would be command line methods just as there have always been when copying files back in my CPM and DOS days. I guess this can compare the copied image on the computer's HD with the one on the SD card. So it would show if anything was changed in the transfer process. And maybe there are transfer programs that have a verify function.
But I don't know how you could compare two different if "identical" images shot on two different cards. Perhaps a visual inspection is the only way.
At root everything is 0 or 1, but there are signaling protocols (commands) for the card that the camera is supposed to note, others that are optional, and others that are strongly recommended. It is a programming interface and not just a stream of bits stored in the card as if one were just pouring bits into a bucket.
The problem has only disappeared with the change of card.
I'm not saying it is the card that caused it but it is definitely related as I haven't seen the issue in a couple thousand shots now. It was in every other shot, or with one card in particular, it was in practically every shot.
I'll will leave the diagnosis to the experts among us but the change of card has certainly rid me of my woes which is really all I'm concerned about.
In answer to the question above, yes the banding and noise become heavier with the increase in ISO.
Also regarding the firmware update, I understand the ability to tether is lost with 1.196. So I stayed at 1.176.
Oh! Well that's interesting! THanks for letting me know. I don't know where I got that. I had read a couple of instances somewhere on the forum here I believe.
Hmmm...even still. Now I have everything working as well as it is I'm going to stick with what I have and not move a muscle.
Maybe, we need to cover the cards with green marker, you know, like those green markers they used to try and sell us to use on the bottom of our CDs to make them sound better. :p
p.s. Paul, just having fun, I believe you, I just don't understand why, either.
