Electronic Viewfinder on the Digilux 2 camera
mikeleng
Hi All
Enclosed is two photographs from two different Digilux 2 cameras.
First one seems to have a protective coating on the EVF thats marked, second one a later model doesn't seem to have any coating at all, the EVF seems clearer and brighter .
Do you think the first one can be cleaned, or can the coating be removed, or is it beyond repair.
Thanks for looking
Mike
The first one appears to have a metal frame on the eyepiece which the second one does not have. Is there any chance that there is an additional lens stuck to the eyepiece of the first one which could be removed?
To me it looks as if the first camera has the rubber surround missing around the eyepiece.
Hi Brucek and Pop
I did take the rubber eyepiece off, hoping it would show the coating, that is coming off
Hi Mcperson
Thanks for your reply my two D2 are 299#### and 300#### so they are from the same period as yours, can't understand it, one with a coating ( dificult to focus) the other without a coating and definitely easier to focus
thankyou for your replies
Regards
Mike
My apologies if this is obvious and you've already tried it, but you're aware that there is a diopter adjustment on the EVF aren't you? The dial to adjust it is on the left side of the EVF.
And out of curiosity, what specifically is making the unit hard to focus?
Bruce
Hi Brucek
Yes I'm aware of the diopter, and I've adjusted it to suit. It's seems to have a haze over it, where my newer one 300****is like new and clear as a bell.
Hi Ron
Yes mine as a bluish coating over it 299**** and it seems to be rubbing off, which seems to suggest its the cause of the haze I'm seeing.
Hi Andy
It looks like a factory coating, I don't know of any other reason why its applied.
Thankyou all again, I'll get to the bottom of it.
regards
mike
Mine is coated and crystal clear. # 2996334. I think most Digilux2 will have a serial number starting something like 298 or 299. I think there were less than 25.000 made. (please correct if wrong)
