j0hnbarker Posted June 10, 2012 Share #1 Posted June 10, 2012 Advertisement (gone after registration) Newbie here with a recently acquired R8 that I'm having problems with... I picked the camera up last week from a local independent shop so it's still covered under their 12 month warranty, but last night I couldn't get it to go into 'P' or 'T' modes at all. When I select 'P' the LED display in the viewfinder shows 'A' and when I select 'T' it shows 'F'. It was all working fine for the first couple of days. I haven't put a film in it yet but was playing about with it to get a feel before I loaded one up. Before I take it back is there anything obvious I should try to do? I'm aware that these cameras had their electrical issues and mine is an early serial number, but I would surely be unlucky to have it fail a few days into my ownership, wouldn't I?! Link to post Share on other sites More sharing options...
Advertisement Posted June 10, 2012 Posted June 10, 2012 Hi j0hnbarker, Take a look here Leica R8 Mode Selection Problem. I'm sure you'll find what you were looking for!
k_g_wolf ✝ Posted June 10, 2012 Share #2 Posted June 10, 2012 (edited) Yes! You better return it, a repair would be too costly. I had a similar problem with my R7 a year ago, it was a EUR 450,-- affair ... Q: - Did you use fresh batteries ? - Did you put in a film and does it behave the same ? and a suggestion: Exercise all cameradials a dozen times. Perhaps just a tiny bit of corrosion or dust is messing things up. Good luck with your camera. In case you have to return it, choose a later R8 next time. Or better, decide for the R9. Best GEORG _____________________________ And: welcome to this forum ! Edited June 10, 2012 by k_g_wolf 1 Link to post Share on other sites More sharing options...
dave.gt Posted June 10, 2012 Share #3 Posted June 10, 2012 Yes! You better return it, a repair would be too costly. I had a similar problem with my R7 a year ago, it was a EUR 450,-- affair ... Q: - Did you use fresh batteries ? - Did you put in a film and does it behave the same ? and a suggestion: Exercise all cameradials a dozen times. Perhaps just a tiny bit of corrosion or dust is messing things up. Good luck with your camera. In case you have to return it, choose a later R8 next time. Or better, decide for the R9. Best GEORG _____________________________ And: welcome to this forum ! Yes, check all functions, etc. and take it back if it can't be cleared up. You could ask for them to fix it, but then, a trouble-free camera would make life much better with such a sweet camera as the R8 or R9! Good luck and let us know what happens. Link to post Share on other sites More sharing options...
topoxforddoc Posted June 10, 2012 Share #4 Posted June 10, 2012 Take it back. Ask them to send it to solms for repair. You will get six months leica warranty. Link to post Share on other sites More sharing options...
j0hnbarker Posted June 10, 2012 Author Share #5 Posted June 10, 2012 Thanks for the advice guys. I tried rotating the mode selection and shutter speed dials but to no avail really. A couple of times I've been able to get the modes to select as they should, but this is obviously an intermittent fault and needs correction. Batteries are new and I tried loading a film but that makes no difference Off back tomorrow - I just hope they can fix it. John Link to post Share on other sites More sharing options...
wildlightphoto Posted June 11, 2012 Share #6 Posted June 11, 2012 Thanks for the advice guys. I tried rotating the mode selection and shutter speed dials but to no avail really. A couple of times I've been able to get the modes to select as they should, but this is obviously an intermittent fault and needs correction. Batteries are new and I tried loading a film but that makes no difference Off back tomorrow - I just hope they can fix it. John When in P or T mode, is the lens at the minimum aperture? 1 Link to post Share on other sites More sharing options...
j0hnbarker Posted June 11, 2012 Author Share #7 Posted June 11, 2012 Advertisement (gone after registration) When in P or T mode, is the lens at the minimum aperture? Hi - yes I stepped the aperture down to 22, but if the camera is working correctly I think the 'P' should flash if you haven't already done this... I took the camera back today and to be fair the shop didn't want to send it back to Leica given the cost of repair, so fully refunded my purchase price + the now defunct roll of film in the camera. I would have preferred to have it repaired, but that didn't seem to be an option. Back on the lookout for a nice R8 Thanks for the help everyone! John 1 Link to post Share on other sites More sharing options...
Dukeviolin Posted April 26, 2018 Share #8 Posted April 26, 2018 (edited) Had precisely the same issue with my new to me R8, set it to f/22 and it's perfect now ! Thanks for the tips Doug ! Edited April 26, 2018 by Dukeviolin Link to post Share on other sites More sharing options...
jip Posted April 27, 2018 Share #9 Posted April 27, 2018 I have an R8 that I bought new (new old stock) for 5 years now. The only reason I see to upgrade to an R9 would be the mode selector lock, and the less weight. I will never sell my R8 though, but it's good to look for one in pristine condition with warranty from a Leica Dealer, so you have peace of mind. Link to post Share on other sites More sharing options...
masjah Posted April 27, 2018 Share #10 Posted April 27, 2018 I have an R8 that I bought new (new old stock) for 5 years now. The only reason I see to upgrade to an R9 would be the mode selector lock, and the less weight. I will never sell my R8 though, but it's good to look for one in pristine condition with warranty from a Leica Dealer, so you have peace of mind. There are several other little tweaks on the R9 that I find quite useful. For example I like the fact that you can illuminate the rear panel display (useful in dark churches). Also both the metering and the the flash control are a little bit more flexible, and there is an HSS facility. Also, if you are pairing with a DMR (not that I am) the R9 is slightly more convenient with regard to switching on and off. Funnily enough I think I would prefer the R9 without the mode selector lock button; on balance I find it a bit of a nuisance. I take the point about whether to upgrade if one already has an R8, but if buying from scratch, I would get an R9 every time, if only because of the longer term issue with failing meter cells on the R8, which writes it off in terms of economic repair. Link to post Share on other sites More sharing options...
