Center split on M8 sensor
mtomalty
Has anyone experienced 'center split' with M8 files.
This is a flaw where a processed file exhibits a difference of exposure from
one side to the other on a horizontal capture and is distinguished by a hard line
In reviewing some M8 raws I shot last week to familiarize myself with the camera
I ran into this problem tonight.
It has been a well documented issue with certain digital backs but I haven't
seen it referenced with a 35mm camera
I'll try to attach a reference but bear with me if I screw up a few times before getting it
right
Mark
Just wanted to add a note for further clarification.
Despite my poor centering of this crop the split occurs symetrically in the frame
from top to,I assume,bottom on a horizontal orientation.
The original is a Raw capture processed in Adobe Lightroom and converted to
black and white in Photoshop. Visible in both color and B+W.
I'll go run the file through Capture One to see if things change
My M8 did it constantly at iso's above 160 BEFORE it went to Solms for upgrade. It has returned with upgrade and Ver 1.09 and no apperent split. It does, however, exhibit a green sripe with liht source right on the edge of the frame.
Is your camera from the early batch and has it been upgraded? This may be the clue.
This is the "Centrefold" problem; rows of pixels are read out of the sensor, left and right, half in one direction, half in the other and the data converted to digital. If that process is not exactly matched for both sides, you will be able to see the join.
It's not the sort of thing which can be just set at the factory and left because it will change over time as the sensor ages and with things like temperature.
TBH, I haven't figured out exactly how they do it, there must be some sort of automatic calibration process using a dark reference and since the last pixels read out from each side are either side of the join, they may also do some other calibration making the assumption that these pixels should be the same on each side.
Hasn't been much of an issue so far, but I have seen discussions on one of the MF back forums where it is clearly a major problem.
Was this one of a series of similar shots? Do they all exhibit the problem?
The camera was not mine and,in fact,belongs to one of the Canadian Leica reps.
As such,I'm not aware of what firmware is installed but I will find out tomorrow and
check back.
The camera was only used for only about an hour so I did not shoot more than one or
two frames of each situation and,therefore do not have any sequences where the
same composition could be compared for the centerfold
Mark
Hi Mark,
I seem to recall reading somewhere on the forum that the M8 sensor is actually made up of two smaller sensors (don't know if it's 4/3 sensors) that have been "Daisy Chained" together. If one of them went out of sync, this would account for the different exposure values resulting in this distinctive line.
Andreas
maybe your screne?
It's approx. one finger width from the upper left corner of the building.
LOL - that depends on the size of your screen - and your fingers!
Look for the faint vertical line in the image. The image has been cropped so it's not perfectly centred...
Hi Mark,
Andreas
Andreas - it's a single sensor but there are two output channels, one reading out the left hand side of the image and the other reading out the right hand side. This is done to reduce the time it takes to get the image samples out of the sensor to about 0.2 seconds. The DMR had only a single channel and was slower as a result.
That is what is happening here - the two sides are going out of sync, or calibration, with each other. Since it's a rep's camera, it might well be back level and early hardware. I heard that the earliest cameras - such as were used at Photokina - were being distributed to retailers as long term demo cameras.
A data point: My early production M8, NOT upgraded physically, does this but only at ISO 2500. It becomes REALLY noticeable if ISO 2500 is underexposed and then the exposure cranked up in raw processing.
It also shows with the edge-exposed Mark Norton green band - but that's really a separate issue of which the visible split is only a byproduct.
No significant difference with firmware v. 1.092 - not better, not worse. One of the first things I checked after loading the new code.
I would say if it is showing at any ISO below 2500, and especially at "daylight" ISOs (640 or below)......and you didn't underexpose and "overdevelop" in RAW......then it's a real problem that needs something fixed.
Guest guy_mancuso
From what I understand it is the processing engine that is off. It is a two channel processing engine for faster write times and one is slower than the other and reason for the split. It's been awhile since we seen this and it's possible the new firmware may correct it. Did this camera have the hardware update.
I receieved my M8 in February, and have been using it for night photography. I immediately encountered the horizontal banding issue, and was constrained to exposures under 30 seconds.
I loaded the new firmware this morning, and took a 180 second exposure at F16 to test the firmware. The banding issue is completely gone, but the split on my sensor is as apparent as ever. You can clearly see that the left side has a green cast to it compared to the right.
Again, this does not appear in daylight shots.
-Mark Flaming
I have a second generation M8, delivered in January with version 1.09 firmware, that exhibited a similar problem to this... only in low light situations and only sometimes. In my case, it appeared as if there was an overlap of sorts, causing it to appear like a vertical ghosted band just right of center. I put the lens cap on and made test shots at various ISO settings and shutter speeds and it appears consistently in those, but it doesn't appear in the vast majority of my shots made in normal shooting circumstances. I was told by Leica that the issue would be fixed with future firmware upgraded. I just upgraded to 1.092 yesterday but haven't tested this out yet.
