jaapv Posted April 16, 2012 Share #21 Â Posted April 16, 2012 Advertisement (gone after registration) Is the red line not a banding? If you see the first sample (you need to magnify the pics to see), the line is black. Â If the line is not a banding, what is the banding problem? Â Thanks, This is a single line problem. Electronic resonance will produce a pattern of wider stripes, as will gross underexposure and recovery. It may also take the form of a tartan pattern. A bright light at the edge of the frame will produce a dark green stripe as wide as the light source to half the sensor width. The last basically only on the M8, although I have seen it described on the M9. Link to post Share on other sites More sharing options...
Advertisement Posted April 16, 2012 Posted April 16, 2012 Hi jaapv, Take a look here M8 repair for Banding problem. I'm sure you'll find what you were looking for!
