M9, LR4 and Corner Fix
Good question, I would also be very interested in the answer - although I fear the profiles LR4 ships with don't cover the lenses that arguably need cornerfix most - the VC 12 and 15mm.
Does anyone know if one can create a custom lens profile in LR?
For those using wide-angle lens on M9, will LR4 with Leica lens profiles obviate the need to use Corner Fix?
LR4 lens profiles do not address (and are not intended to address) color shifts on the edges/corners, which is what CornerFix does. Such color shifts should(!), in the Leica scheme of things, be addressed in firmware via the lens coding system before LR ever sees the image.
Eric Chan, who is on the Camera Raw engineering team (the folks responsible for the raw image processing in LR), implied that CornerFix type functionality might come to LR in the future - see this thread on the Adobe forums: Adobe Forums: Is there a Cornerfix solution built into Lightroom?
Sandy
Don't understand. Isn't Corner Fix a post-processor? So what it sees, LR4 should also see. Of course, LR4 may not have a standard built-in feature, but isn't that what a lens profile does?
The color shifts are sensor issues rather than lens issues - put the same lens on an M8, M9, NEX-5 and NEX-7, you get different patterns of color shifts. The way Adobe lens profiles are designed is to correct for lens imperfections - imperfections that are the same regardless of sensor e.g., barrel distortion, etc.
Sensor issues such as red edge should be corrected via camera profiles - in the Adobe world, DNG Camera profiles (DCP files). However currently DNG Camera profiles don't have the capability to effectively correct red-edge.
Sandy
I'm sure Adobe will come up with something. They need to to compete with C1. It is not only the M9 that has the problem, it is on medium format files as well.
Hi,
Can anyone with LR4 say for sure that it supports M lens profiles, and perhaps how effective this is? Im particular interested in the WATE profiles.
Im currently using LR3.5 and will perhaps at some time upgrade, but I absolutely hate SW upgrades of any kind. If its working dont fix it. For me it seems that the time spent in re-learning SW is never justified :confused:.
I have not tried the wate profiles, not owning one, but when I tried some other profiles in ACR I did not see much effect. A bit of distortion correction maybe.
Even coded lenses on my M8 are not perfect out of camera, specially at wide apertures.
I let the coding do as much as it can, then I have cornerfix profiles to touch up the photo before commencing post processing.
Even snow scenes are perfect this way, just like my Nikon images right out of camera.
Hi,
LR4 does have profiles for M lenses and they work well. I just processed a batch of images made with a VC 21 (manually coded as 11135); they exhibit the red edge and that gets fixed in Cornerfix. Once these are imported into LR4 I apply the 21 Elmar profile and voila!
Jean-Michel
Steve Huff has some M9 with 35 ASPH images with lens recognition off & on. On seems to be a 90% fix with some residual cyan corners.
I touch up in camera files corrected with lens recognition and then with corner fix. They then get perfect.
Hi,
-No WATE profiles in LR 4.
-Only distortion and, perhaps, vignetting correction for other M-profiles AFAIK.
-I tried a 21 profile for the WATE: result wad minimal.
