j_w_davies Posted March 19, 2012 Share #1 Posted March 19, 2012 Advertisement (gone after registration) Every time I switch my Digilux 2 on I get the following message: Please set the clock clock set - menu Yes, the clock needs reseting as it's gone back to the 1/1/2004 date. Not the biggest problem, but a bit annoying. Does anyone have any ideas for a solution? Link to post Share on other sites More sharing options...
Advertisement Posted March 19, 2012 Posted March 19, 2012 Hi j_w_davies, Take a look here Digilux 2 - Start Up Problem. I'm sure you'll find what you were looking for!
pop Posted March 19, 2012 Share #2 Posted March 19, 2012 The clock will stop running if you leave the camera for some time without any battery inserted or if the battery becomes empty. Suggestion: use your D2 more often. It deserves it. Link to post Share on other sites More sharing options...
wda Posted March 19, 2012 Share #3 Posted March 19, 2012 It is probably power supply related. Older batteries do lose capacity over time although my originals are still performing. Philip may be on the right track. Link to post Share on other sites More sharing options...
j_w_davies Posted March 19, 2012 Author Share #4 Posted March 19, 2012 It's true that I don't leave the battery in, when the camera isn't in use. The clock set issue has only started recently though, and the camera doesn't reset any of the other functions. Is there an internal battery that can be replaced? Link to post Share on other sites More sharing options...
farnz Posted March 21, 2012 Share #5 Posted March 21, 2012 It sounds like the motherboard battery has run down. I suspect that if you leave a fresh D2 battery in your camera for a day or two your mobo battery will charge from it, you'll be able to reset the clock and your D2 will be happy again. I remember that forum member Audidudi posted a documented D2 teardown a few years ago so if you needed to change the mobo battery a search for that thread would help you. Pete. Link to post Share on other sites More sharing options...
j_w_davies Posted March 21, 2012 Author Share #6 Posted March 21, 2012 Thank you. I'll give it a go. Link to post Share on other sites More sharing options...
j_w_davies Posted March 27, 2012 Author Share #7 Posted March 27, 2012 Advertisement (gone after registration) I gave it a go, and it worked. Thank you Pete. Link to post Share on other sites More sharing options...
farnz Posted March 27, 2012 Share #8 Posted March 27, 2012 I gave it a go, and it worked. Thank you Pete. Very glad to hear it, j_w_, and thanks for reporting back so it might help members in the future. Pete. Link to post Share on other sites More sharing options...
