johnthegasman Posted February 11, 2012 Share #1 Posted February 11, 2012 Advertisement (gone after registration) Hi everyone, anyone know of R9's not taking pictures when the camera is very cold. The electrics all work and when you press the shutter you hear a clonk but the mirror and shutter do not operate, when I take the camera back in the warm it is perfect. I have checked the batteries with an AVO meter and they are reading 3 volts warm or freezing cold. Any comments or help would be appreciated. Cheers John. Link to post Share on other sites More sharing options...
Advertisement Posted February 11, 2012 Posted February 11, 2012 Hi johnthegasman, Take a look here Leica R9 not working in cold weather . I'm sure you'll find what you were looking for!
masjah Posted February 11, 2012 Share #2 Posted February 11, 2012 Hi everyone, anyone know of R9's not taking pictures when the camera is very cold. The electrics all work and when you press the shutter you hear a clonk but the mirror and shutter do not operate, when I take the camera back in the warm it is perfect. I have checked the batteries with an AVO meter and they are reading 3 volts warm or freezing cold. Any comments or help would be appreciated. Cheers John. Does your AVO have a "battery test" function that tests the batteries "on load". A conventional "off load" voltage measurement can give a misleading almost nominal voltage. I'd swap the batteries for new ones and see what happens. Link to post Share on other sites More sharing options...
johnthegasman Posted February 11, 2012 Author Share #3 Posted February 11, 2012 Thank you John, I have had the symptom B4 and changed the batteries for brand new. I was in Bulgaria at Xmas 8 degrees below and the camera did not take pictures, just a clonk no mirror or shutter, I think. When I got back to the UK, more new batteries, the camera was perfect but the temperature was normal! Soon as the temperature drops no pictures!!! Anyone or John got any ideas, are Leica still servicing R9's? Cheers John. Link to post Share on other sites More sharing options...
masjah Posted February 12, 2012 Share #4 Posted February 12, 2012 Thank you John,I have had the symptom B4 and changed the batteries for brand new. I was in Bulgaria at Xmas 8 degrees below and the camera did not take pictures, just a clonk no mirror or shutter, I think. When I got back to the UK, more new batteries, the camera was perfect but the temperature was normal! Soon as the temperature drops no pictures!!! Anyone or John got any ideas, are Leica still servicing R9's? Cheers John. John, sorry to hear that - I'm afraid I can't think of anything else myself. I'm sure R9s are still being serviced by Leica. Link to post Share on other sites More sharing options...
dave.gt Posted February 12, 2012 Share #5 Posted February 12, 2012 Hmmm... Norbert Rosing never seems to have that problem...maybe someone will chime in with a similar experience or solution. Good luck. Link to post Share on other sites More sharing options...
Stealth3kpl Posted February 12, 2012 Share #6 Posted February 12, 2012 I can only thing that, if it's not the power source, it must be lubricant getting stiff in cold temperatures. Pete Link to post Share on other sites More sharing options...
dave.gt Posted February 12, 2012 Share #7 Posted February 12, 2012 Advertisement (gone after registration) I can only thing that, if it's not the power source, it must be lubricant getting stiff in cold temperatures.Pete Yeah, just thinking about that an how a CLA might be in order. If I had an R9, that would be the first thing I would do to make sure it is not the lubricant. Link to post Share on other sites More sharing options...
RFNewcomer Posted February 12, 2012 Share #8 Posted February 12, 2012 I shot slide film in -20 C or more last winter with my R9 with no problems. At these kinds of temperatures, especially if it's windy, it's always a good idea to return your camera to your bag as quickly as possible, of course. So if it's not your battery that's playing up, you should probably follow the advice of the other posters and get your camera checked out. Link to post Share on other sites More sharing options...
janki Posted February 12, 2012 Share #9 Posted February 12, 2012 Hi John! It is interesting to read about your experience. I have seen something similar. When photographing in temperatures below freezing point with my Leica R9, it happens that the mirror remains in the upper position, and do not return after the picture has been taken. I also believed at first that it was due to weak batteries. Gradually I discovered that the switch, which can be turned to lock the mirror in the upper position, was very sensitive. It must always be very hard pressed towards the normal position. This has been true from the camera was new; so I actually should have had it repaired by Leica while it was still under warranty. Now I know, that if the mirror stops in the upper position, still the image has been correctly exposed. I just press the shutter again to return the mirror. Irritating, - of course - but it only happens when it is cold, and only occasionally. Regards! Link to post Share on other sites More sharing options...
johnthegasman Posted February 12, 2012 Author Share #10 Posted February 12, 2012 Hi everyone, had a real busy day, so only just logged on, thanks to every one that has posted a reply. I will contact Leica in Solms tomorrow and inquire if they do CLA on the R9, if they do and it is reasonable, It will B on its way there! Anyone know of someone in UK that could do it? Cheers John. Link to post Share on other sites More sharing options...
Stealth3kpl Posted February 13, 2012 Share #11 Posted February 13, 2012 http://www.l-camera-forum.com/leica-forum/customer-forum/176369-repair-specialists.html Pete Link to post Share on other sites More sharing options...
johnthegasman Posted February 19, 2012 Author Share #12 Posted February 19, 2012 Hi, thanks for all the info, I have contacted Leica who have sent me a shipping label for the return of the R9 it's booked in for a service CLA but until the technician inspects it there is no price. They will give me an estimate after inspection. I will post the cost for anyone who may interested in sending their Leica R9 to Solms. Cheers John. Link to post Share on other sites More sharing options...
Simon Delange Posted January 25, 2015 Share #13 Posted January 25, 2015 Same problems in Iceland, temps betwen 0°C and _10°C... Link to post Share on other sites More sharing options...
