Nuit Posted February 6, 2012 Share #1 Posted February 6, 2012 Advertisement (gone after registration) Do you know the 6 bit code start from what serial no.? I think would be around 38XXXX. Thank you very much for all reply. Link to post Share on other sites More sharing options...
Advertisement Posted February 6, 2012 Posted February 6, 2012 Hi Nuit, Take a look here 6 bit serial no.. I'm sure you'll find what you were looking for!
lct Posted February 6, 2012 Share #2 Posted February 6, 2012 All lenses having left the factory since July 1st, 2006 do have the new coding normally so the first serial numbers should be larger than 3,900,000 i guess. Link to post Share on other sites More sharing options...
bocaburger Posted February 6, 2012 Share #3 Posted February 6, 2012 You do know that the only thing different about a coded lens are the pits engraved/painted in the rear flange, right? A lens subsequently coded by Leica would be the same as one which came from the factory coded. And in terms of functionality, if done properly an aftermarket-milled coding has the same functionality as a factory coding. Link to post Share on other sites More sharing options...
lct Posted February 6, 2012 Share #4 Posted February 6, 2012 ...in terms of functionality, if done properly an aftermarket-milled coding has the same functionality as a factory coding. Are you sure? when Leica code a pre-coding lens, they calibrate it for digital i've been told. Don't ask me what such calibrating may consist in though. My dremel tool cannot answer anyway. Link to post Share on other sites More sharing options...
