ksporry Posted January 6, 2012 Share #1 Â Posted January 6, 2012 Advertisement (gone after registration) Hey guys, Â I am considering getting a Nokton 25mm F0.95. I like light strong lenses for low light situations. However, this particular lens does not come with an M-mount (Micro-4/3 only). Is it posisble to use an adapter to fit this on my M8.2? Also, how would it perform on a Leica? I guess there is the risk that the M8.2 sensor (APS-C I believe) is too big for this particular lens (M-4/3). It'd still be worth checking though as it is an affordable low light lens. Any opinions? Link to post Share on other sites More sharing options...
Advertisement Posted January 6, 2012 Posted January 6, 2012 Hi ksporry, Take a look here Nokton 25mm F0.95. I'm sure you'll find what you were looking for!
jaques Posted January 6, 2012 Share #2 Â Posted January 6, 2012 i don't know exactly why but I am pretty sure this lens cannot be used on an M mount camera... Link to post Share on other sites More sharing options...
adan Posted January 6, 2012 Share #3 Â Posted January 6, 2012 Won't work. The lens MIGHT barely cover the M8's cropped sensor (likely not), but the real problems are: Â 1. No way to focus (no RF cam connection). Scale-focusing a 25mm is possible at f/4, but not at f/1.4 (which eliminates the whole purpose of the lens - might as well get the Skopar 25 f/4 already made in M-mount). Â 2. m4/3rds mount-to-sensor distance is shorter than Leica Ms. M lenses can go on m4/3rds with room for an adapter, but not vice versa. The extra depth of the M8 would act like an extension tube, leaving you with a macro-only lens (and still no way to focus). Link to post Share on other sites More sharing options...
stefani88 Posted January 10, 2012 Share #4  Posted January 10, 2012 Hey guys, I am considering getting a Nokton 25mm F0.95. I like light strong lenses for low light situations. However, this particular lens does not come with an M-mount (Micro-4/3 only). Is it posisble to use an adapter to fit this on my M8.2? Also, how would it perform on a Leica? I guess there is the risk that the M8.2 sensor (APS-C I believe) is too big for this particular lens (M-4/3). It'd still be worth checking though as it is an affordable low light lens. Any opinions?  I also think so. Link to post Share on other sites More sharing options...
Guest Posted January 15, 2012 Share #5 Â Posted January 15, 2012 Is there a Sony Nex version of this lens? Link to post Share on other sites More sharing options...
pico Posted January 15, 2012 Share #6  Posted January 15, 2012 Hey guys, I am considering getting a Nokton 25mm F0.95. I like light strong lenses for low light situations. However, this particular lens does not come with an M-mount (Micro-4/3 only). Is it posisble to use an adapter to fit this on my M8.2? Also, how would it perform on a Leica? I guess there is the risk that the M8.2 sensor (APS-C I believe) is too big for this particular lens (M-4/3). It'd still be worth checking though as it is an affordable low light lens. Any opinions?  It will not work on any Leica M even should you find or make an adapter. Besides the backspace issue, there is no coupling to the rangefinder. It is a superb lens, still rather difficult to use on an M-43 (entirely manual f-stop and focus), but I got a G1 just to use the lens. It is very sharp wide-open even at minimum distance.  Full frame wide open Actual pixel crop Link to post Share on other sites More sharing options...
luigi bertolotti Posted January 15, 2012 Share #7 Â Posted January 15, 2012 Advertisement (gone after registration) Is there a Sony Nex version of this lens? Â No, afaik... in theory a micro 4/3 lens could be adapted on a Nex body (flange distance : 18mm for Nex, 20mm for m43), but don't know if adapters do exist... and neither if the Voigtlander 25 f 0,95 does cover the APS-C format of Nex, which is anyway larger than Micro 4/3. Link to post Share on other sites More sharing options...
