Timmyjoe Posted January 5, 2012 Share #1 Â Posted January 5, 2012 Advertisement (gone after registration) Just picked up a Zeiss 25 Biogon from B&H. Really like the focal length on my M8.2 but when I tested the lens this afternoon, when shooting with the sun off to my left, I am getting a weird prism spot on all the shots. Originally started with the lens shade and the IR cut filter in place. When I noticed the spot, I took the lens shade and the IR cut filter off the lens, but the spot is still there on each shot. Â Then took my 35 cron asph and shot the same scene, no spot. Â Can anyone tell me what is causing this and if this is just something with the Zeiss lenses? I think it could become an issue with the photo documentary work I plan on doing with the lens. Â Here are three shots. First a shot from the 25 Biogon showing the prism spot, then the same scene with the 35 cron asph where no spot appears, and finally a zoom in on the spot, showing the prism pattern. Â [ATTACH]294746[/ATTACH] Â Â [ATTACH]294747[/ATTACH] Â Â [ATTACH]294748[/ATTACH] Â Thanks for any and all assistance on this. Being that it is B&H, if I can't solve this, then the lens is going back. Link to post Share on other sites More sharing options...
Advertisement Posted January 5, 2012 Posted January 5, 2012 Hi Timmyjoe, Take a look here Help, lens issue. I'm sure you'll find what you were looking for!
Wrersanddaw Posted January 5, 2012 Share #2 Â Posted January 5, 2012 Hello guys, cool forum you have Link to post Share on other sites More sharing options...
UliWer Posted January 5, 2012 Share #3 Â Posted January 5, 2012 Having no Zeiss lenses I am not sure wether this is right, but it has been described elsewhere in this forum and in the Rangefinder Forum that some Zeiss lenses cause a light leak in the camera because a screw at the lens is exactly at the same position of a screw at the M bayonet. This can be solved easyly by putting some black colour on the screws or at the Zeiss customer service. Â Though may be in your case it's something external. Link to post Share on other sites More sharing options...
Timmyjoe Posted January 6, 2012 Author Share #4 Â Posted January 6, 2012 Yeah, I can't figure it out. Did a light leak test and that doesn't seem to be the issue. It's weird. Link to post Share on other sites More sharing options...
jaapv Posted January 6, 2012 Share #5 Â Posted January 6, 2012 It looks like one coma spot in an odd place. Weird indeed. I guess it is a flaw in the lens. Return it, I would say. Link to post Share on other sites More sharing options...
pgk Posted January 6, 2012 Share #6 Â Posted January 6, 2012 Given that its showing varying colours (prism pattern) I'd say that its been through glass as the light has been split - so not a light leak. As a guess I'd suggest it might just be reflected light from inside the lens - a bright spot or possibly even a minute chip on the periphery of one of the elements which has reflected a bright light source obliquely through one or more elements and onto the sensor. See if you can use a torch shining obliquely into the lens to recreate the effect and whether its only with light from one direction - this may give you a clue as to where to examine in more detail. Link to post Share on other sites More sharing options...
