fabiobarbato Posted January 3, 2012 Share #1 Posted January 3, 2012 Advertisement (gone after registration) It has happened more than one time. When I'm around frame 25 of a film, I can't advance the film anymore....it is like I have reached the end of the film. Does anyone know why it this happening?? thanks Link to post Share on other sites More sharing options...
Advertisement Posted January 3, 2012 Posted January 3, 2012 Hi fabiobarbato, Take a look here My M6 TTL is jamming around frame 25. I'm sure you'll find what you were looking for!
earleygallery Posted January 3, 2012 Share #2 Posted January 3, 2012 You are sure that you're not using a 24exp roll of film? Link to post Share on other sites More sharing options...
stunsworth Posted January 3, 2012 Share #3 Posted January 3, 2012 It's probably caused by the washers under the rewind crank jamming as the film is advanced. I had the same problem, but in my case it was after 15-18 frames. If you want to try and fix it yourself there are some details here... rewind mechanism transport problem To remove the rewind crank insert a screwdriver in the slot you can see in the crank, and then turn the rewind crank anti-clockwise whicle holding the screwdriver firmly. There are a number of washers underneath the crank itself. Having no mechanical skills what so ever I sent mine away to be fixed. Link to post Share on other sites More sharing options...
fabiobarbato Posted January 3, 2012 Author Share #4 Posted January 3, 2012 Hehehe....thanks, but I'm sure I'm using a 36 frames. Link to post Share on other sites More sharing options...
maurometallo Posted January 3, 2012 Share #5 Posted January 3, 2012 I can confirm what Steve said. It happened to my fried's M4-2 and we brought the camera to Kindermann (authorized Leica repair center in Toronto). Gerry the technician let us watch: It was a pretty easy fix and he was done in litterally 5 minutes. Link to post Share on other sites More sharing options...
fabiobarbato Posted January 3, 2012 Author Share #6 Posted January 3, 2012 Thanks stunsworth and maurometallo!! Glad to hear is a simple fix. Link to post Share on other sites More sharing options...
normclarke Posted January 3, 2012 Share #7 Posted January 3, 2012 Advertisement (gone after registration) Don't forget to loosen the small set screw before unscrewing the rewind knob. Best, normclarke Link to post Share on other sites More sharing options...
earleygallery Posted January 4, 2012 Share #8 Posted January 4, 2012 Hehehe....thanks, but I'm sure I'm using a 36 frames. I've done it myself, wondered why the camera jammed then realised I'd picked up a 24exp roll of film! Link to post Share on other sites More sharing options...
