Jon Pop Posted October 26, 2011 Share #1 Â Posted October 26, 2011 Advertisement (gone after registration) Hello, I just purchased a Zeiss 35mm Biogon C f2.8 lens, heard lots of great things about it and it was a good price. What I'm wondering is the preferred setting for the lens profile - I know I could 'play around and experiment' myself, but if someone out there who is an avid M9 user (I'm new to the M9, usually using my MP) has come up with the best lens profile to pick from the M9 menu, I'd love to know. I don't want to pixel peep for hours looking around. Â I have the latest firmware. I notice that the Summarit 35 f2.5 isn't in the lens profile (it has the closest minimum aperture so I'd thought about using that one). I've heard some say 'use the 35mm f2 summicron pre-asph', but wanted to ask the question anyway. I want to get the best performance from this lovely lens on my M9; don't want to blame vignetting or anything like that on the lens when I've simply not picked the best profile. Nor am I interested in performing lots of post-production corrections. Â I appreciate everyone's advice! Cheers, Jon Link to post Share on other sites More sharing options...
Advertisement Posted October 26, 2011 Posted October 26, 2011 Hi Jon Pop, Take a look here Advice Please: Zeiss Biogon C 35mm f2.8 best lens code. I'm sure you'll find what you were looking for!
StephenPatterson Posted October 27, 2011 Share #2 Â Posted October 27, 2011 ...I've heard some say 'use the 35mm f2 summicron pre-asph', but wanted to ask the question anyway... Â That's the one I used (011100) with my Zeiss 35/2.8 Biogon C and it worked very well. In all honesty I don't think it's nearly as critical at 35mm as 28mm and wider. 1 Link to post Share on other sites More sharing options...
Jon Pop Posted October 27, 2011 Author Share #3 Â Posted October 27, 2011 Thanks - I thought 011100 was the 28 f2.8 asph code? Did you use that b/c of the 2.8 aperture, or the 35 f2 non-aspheric? Cheers, Jon Link to post Share on other sites More sharing options...
spylaw4 Posted October 27, 2011 Share #4 Â Posted October 27, 2011 This give 000110 as the code. I did have the lens some time ago but can't recall the code I used. It was probably 000110 as suggested. Link to post Share on other sites More sharing options...
GLAUMAX Posted October 27, 2011 Share #5 Â Posted October 27, 2011 I also use the code of the 35mm Summicron pre-asph Link to post Share on other sites More sharing options...
01af Posted October 27, 2011 Share #6  Posted October 27, 2011 (edited) 6-bit lens codes to try with the Zeiss C-Biogon 35 mm 1:2.8 ZM include these (0 = white patch/no patch; 1 = black patch):  6 (000110) – Summicron-M 35 mm 1:2 25 (011001) – Elmarit-M 24 mm 1:2.8 Asph 30 (011110) – Summicron-M 35 mm 1:2 Asph 43 (101011) – Summarit-M 35 mm 1:2.5 I don't know which of these will be the best. The first I'd try are 43 and then 6. If the Biogon has a lot of vignetting then it may be worth trying the 24 mm Elmarit's code even though the focal length doesn't match. Codes for 28 mm or 50 mm lenses won't work at all.   That's the one I used (011100) with my Zeiss C-Biogon 35/2.8 ZM and it worked very well. If the 6-bit code you're using works well with your 35 mm lens then it cannot be 011100. Edited October 27, 2011 by 01af Link to post Share on other sites More sharing options...
StephenPatterson Posted October 27, 2011 Share #7  Posted October 27, 2011 Advertisement (gone after registration) Thanks - I thought 011100 was the 28 f2.8 asph code? Did you use that b/c of the 2.8 aperture, or the 35 f2 non-aspheric?Cheers, Jon  Sorry, I grabbed the wrong lens!!! Doh!!!! The code I've been using is 000110  I do agree with paulmac that coding is much less critical at 35mm than wider focal lengths. Link to post Share on other sites More sharing options...
pico Posted October 27, 2011 Share #8 Â Posted October 27, 2011 Try no lens setting first. Â Biogons are unique in that neither coverage nor vignetting are improved by stopping down. Link to post Share on other sites More sharing options...
daniel buck Posted November 3, 2011 Share #9 Â Posted November 3, 2011 Other than for the EXIF don't bother the lens works and looks fine without any code. Â agreed, I have been using mine with no code, and I don't feel that it needs any. Link to post Share on other sites More sharing options...
microview Posted November 3, 2011 Share #10  Posted November 3, 2011 The resolution of this lens is outstanding and although I still hanker after the current Summicron ASPH (at three times the price) comparison shots from two examples I have previously owned are in an inferior class. Maybe I was unlucky with the samples, as others note 'exceptional sharpness' for the 35 Summicron. Ergonomically the Zeiss is not as good as the Summicron but optically it is on a par with my 50 Summilux ASPH – and that's saying something! I code as 35 Summicron pre-ASPH but not coded at all I can't say I see real differences: of course in Lightroom it will show as [–] and you may prefer it to show as, at least, 35mm. 1 Link to post Share on other sites More sharing options...
Mahesh Posted May 24, 2021 Share #11 Â Posted May 24, 2021 This is a very old post but I am excited after getting this little biogon. What seems to work on M10p for me, is possibly 28 summaron's profile. Link to post Share on other sites More sharing options...
pedaes Posted May 24, 2021 Share #12  Posted May 24, 2021 13 minutes ago, Mahesh said: This is a very old post but I am excited after getting this little biogon. What seems to work on M10p for me, is possibly 28 summaron's profile. If it works for you that’s great! Link to post Share on other sites More sharing options...
