Aperture ring on 28mm Elmarit-M
Perceval
I have bought a fourth version 28mm f2.8 Elmarit-M lens, in excellent condition, according to the dealer who sold it to me. I find that the aperture setting ring, while it does indeed fit into place at every stop and half-stop, has a soft feel, lacking the positive and firm action of my 1958 Summicron. Is this a normal feature of modern lenses?
They do vary with wear and usage. The settings should not change inadvertently; that is my test. I once rejected a 90 macro lens for an opposite reason. The lens unlocked before the aperture changed. Went back to Leica and returned with same fault. Rejected reluctantly because operation was not Leica-like.
yeah, apperture ring clicks much more precise and firm on my DR 50 summicron from 60s than on my new 50 lux. And my 35 cron asph, purcahsed new few months ago, got some play on apperture "edges", for example when set to 2, you still can move it littble bit farther. Shame.
You shouldn't compare the mechanical quality of old and new lenses. In general, the modern stuff doesn't compare too favourably with the beautifully engineered stuff made pre-1970-ish. Loose and wobbly with bits falling off (e.g. 28 Summicron) is what you tend to find nowadays, though Leica seem (if you excuse the pun) to have have tightened things up more recently with their most expensive summilux lenses.
My 28mm Elmarit-M (Version III) from 1990 has the same “issue”. It was quite disconcerting at first as my main lens is a 50mm Summicron rigid (name’s the game, also for the aperture ring), but then I became used to it.
As the others above I think it’s a normal “feature” of more modern Leica lenses. My Summarit-M 50mm feels almost exactly the same. The Voigtländer Ultron 28mm though has the nice click I enjoy so much with the ’cron.
Cheers,
-Sascha
Thanks everyone; It seems I do not have to send the lens off for maintenance. Incidentally, I also have a Canon 35mm f2 made in 1960, as solidly built and positive in action as it was when first made; but I will look more closely at contemporary Zeiss lenses in future. (Although I do not like everything clinically sharp......)
  • 3 months later...
Hi, just to revive this thread a little bit.
So it is not abnormal for leica lens to have a little play - ie going slightly beyond the smallest and biggest aperture, just slightly beyond.
How about if the aperture ring have a slight play axially - along the axis of the lens barrel?
all Leica lenses go slightly above and below the aperture range
no I don't see any play on the axis of the lens barrel that on my Leica lenses. They are all perfectly lined up
I have slight rattles when I shake them if my ear is to the lenses
I would definitely exchange a lens that had any movements I wasn't happy with
