Guytou Posted July 22, 2011 Share #1 Posted July 22, 2011 Advertisement (gone after registration) Hello, I ordered two batteries for LC1 (CGR-S602E) with tension 7.2 V and 1500 mAh at Subtel in Germany. I received the two batteries but the label mentions Li-ion 7.4 V - 1500 mAh - 11 Wh. Is that dangerous for my D2 and LC1 as well as the battery chargers ? Thank you with you. Guy Link to post Share on other sites More sharing options...
Advertisement Posted July 22, 2011 Posted July 22, 2011 Hi Guytou, Take a look here Battery LC1/D2. I'm sure you'll find what you were looking for!
brucek Posted July 22, 2011 Share #2 Posted July 22, 2011 I wouldn't use them, but that is certainly your choice. I don't think they would have a problem with the chargers but I'd be concerned about the higher voltage possibly damaging the cameras. Link to post Share on other sites More sharing options...
Guytou Posted July 22, 2011 Author Share #3 Posted July 22, 2011 OK, thank you for your answer. I had an opinion of a technician who tells me that this difference of 0.2 V poses internal problem neither with the apparatus nor with the charger. They are batteries known as “compatible” but I fear to make an error and I do not know if I will preserve them.: Confused: Two batteries of Leica origin cost 150 €… Guy Link to post Share on other sites More sharing options...
farnz Posted July 22, 2011 Share #4 Posted July 22, 2011 Guy, As an Engineer who has designed dc power supply systems, 0.2 Volts will not be a problem. The stated voltage on a 7.4 Volt battery is subject to precision error that is larger than the 0.2 Volt difference you're concerned about. Pete. Link to post Share on other sites More sharing options...
Guytou Posted July 22, 2011 Author Share #5 Posted July 22, 2011 Thank you for your answer Farnz. But the problem is solved : I returned the two adaptable batteries for refunding and I ordered two batteries of origin D2/LC1 at Leica (120 € TTC with send understood.) This time the tariffs of the Panasonic models were more expensive and the batteries much more complicated to obtain. My head is quieter…: Rolleyes: Guy Link to post Share on other sites More sharing options...
dhsimmonds Posted July 23, 2011 Share #6 Posted July 23, 2011 Thank you for your answer Farnz.My head is quieter…: Rolleyes: Guy But your wallet is now a lot thinner! Link to post Share on other sites More sharing options...
Guytou Posted July 23, 2011 Author Share #7 Posted July 23, 2011 Advertisement (gone after registration) When I go to the sky, my visa card will not follow me and I will not make any more an expenditure… Guy Link to post Share on other sites More sharing options...
caver3d Posted July 24, 2011 Share #8 Posted July 24, 2011 You can get the appropriate replacement third party batteries for the LC1 and D2 on ebay. They work just fine and cost much less. - Chuck Link to post Share on other sites More sharing options...
Guytou Posted July 24, 2011 Author Share #9 Posted July 24, 2011 OK, thanks. My purchase is made and my two new batteries of origin will be there very soon. Guy Link to post Share on other sites More sharing options...
Paul Reading Posted July 24, 2011 Share #10 Posted July 24, 2011 I bought a third party battery and it is useless it does not hold a charge sometimes I turn on the camera and it is dead. The last "Original" battery has lasted how long 5 years is it since the Digilux 2 was launched so 15 euros a year. It still grates but I know it will not cause problems. Link to post Share on other sites More sharing options...
Guytou Posted July 24, 2011 Author Share #11 Posted July 24, 2011 I bought a third party battery and it is useless it does not hold a charge sometimes I turn on the camera and it is dead. The last "Original" battery has lasted how long 5 years is it since the Digilux 2 was launched so 15 euros a year. It still grates but I know it will not cause problems. I think also so ! I already had also this same problem with batteries known as “compatible” which did not keep the load well. Therefore I have just bought two batteries of origin. The low-costs return sometimes much expensive… Guy Link to post Share on other sites More sharing options...
ajthornbury Posted July 24, 2011 Share #12 Posted July 24, 2011 I use hahnel batteries type HL-DC3/LC1 with no problems on my D2. Charge appears to last as long as the original bleica batteries. Link to post Share on other sites More sharing options...
ajthornbury Posted July 24, 2011 Share #13 Posted July 24, 2011 I use hahnel batteries type HL-DC3/LC1 with no problems on my D2. Charge appears to last as long as the original bleica batteries. Link to post Share on other sites More sharing options...
Guytou Posted July 24, 2011 Author Share #14 Posted July 24, 2011 I think that all the batteries known as “compatible” are not equal quality. It is like a lottery and this problem does not seem to exist with the models of origin. Guy Link to post Share on other sites More sharing options...
Guytou Posted July 24, 2011 Author Share #15 Posted July 24, 2011 I think that all the batteries known as “compatible” are not equal quality. It is like a lottery and this problem does not seem to exist with the models of origin. Guy Link to post Share on other sites More sharing options...
