maccaco Posted June 18, 2011 Share #1 Posted June 18, 2011 Advertisement (gone after registration) I use a cover for my M8 and each time I need to use a tripod I need to remove it, and it is quite annoying. I've thought of a tripod with a clamp and I found the "Kestrel Weather Meter Tripod Clamp" I could use my tripod. Do you know of any other similar option? Link to post Share on other sites More sharing options...
Advertisement Posted June 18, 2011 Posted June 18, 2011 Hi maccaco, Take a look here Tripos clamp and M8 with cover, possible?. I'm sure you'll find what you were looking for!
wda Posted June 18, 2011 Share #2 Posted June 18, 2011 I am not sure what cover you use; but the neoprene case peels off easily and is quickly attached to a tripod. Link to post Share on other sites More sharing options...
maccaco Posted June 18, 2011 Author Share #3 Posted June 18, 2011 The cover is leather and has no rear hole to screw the tripod screw, and I would not mess it (they are expensive covers) Link to post Share on other sites More sharing options...
mmradman Posted June 18, 2011 Share #4 Posted June 18, 2011 Do yourself a favour; when using tripod remove protective case and use decent plate/tripod head, maybe Leica own ball head. That Kestrel clamp is a joke for any decent camera. Link to post Share on other sites More sharing options...
maccaco Posted June 18, 2011 Author Share #5 Posted June 18, 2011 Do yourself a favour; when using tripod remove protective case and use decent plate/tripod head, maybe Leica own ball head. That Kestrel clamp is a joke for any decent camera. If you are absolutely right, but I'm lazy when I want to shoot a few photos at low speed ... end finish removing the cover, I know Link to post Share on other sites More sharing options...
farnz Posted June 18, 2011 Share #6 Posted June 18, 2011 How much shock will your cover absorb when your camera hits the ground? Pete. Link to post Share on other sites More sharing options...
maccaco Posted June 19, 2011 Author Share #7 Posted June 19, 2011 Advertisement (gone after registration) How much shock will your cover absorb when your camera hits the ground? Pete. mmm ... over a hundred rude words Link to post Share on other sites More sharing options...
AncientCityPhoto Posted June 23, 2011 Share #8 Posted June 23, 2011 You could get a Luigi case with a tripod thread on the bottom. Then attach a basic Really Right Stuff or Wemberly camera plate to the bottom. You can then keep the case on and easily quick release onto most ball heads from Kirk, RRS, etc... Link to post Share on other sites More sharing options...
maccaco Posted June 25, 2011 Author Share #9 Posted June 25, 2011 You could get a Luigi case with a tripod thread on the bottom. Then attach a basic Really Right Stuff or Wemberly camera plate to the bottom. You can then keep the case on and easily quick release onto most ball heads from Kirk, RRS, etc... Yes, thanks!. I am looking for a solution that way. Regards Link to post Share on other sites More sharing options...
