Brighter Visoflex focusing screen?
Washington
I fitted the slightly modified Canon Mk III Ds screen, and unlike the thinner spit-image
screen K-H sent me, this one back focuses 3’’ at 8 feet….. photo’s were noticeably
unsharp at longer distance. I removed the two .2mm shims and back focus increased
dramatically. So, when I get some shims together: this will be corrected.
The fine-matt screen is definitely the better choice though. It is brighter and very clear.
However, all in all, there is nothing wrong with the ‘’stock’’ glass screen.
After a few hours of adjusting and getting it right and now trying out assorted lenses
on it I find the longer teles create some sort of strange pattern on the screen that
look like feint radial cracks.
Conclusion: phooey.
It’s not all that brighter than the glass Leica screen anyway…. having a clean mirror
and prism assembly is more important than this exercise …. so it’s back to the original
screen.
Naturally there my be other screens people have had better results with but it sure isn’t
this one. Cheers.
K-H,
After removal and magnified inspection the ‘’radial lines’’ were minute scratches
caused by me handling and fitting the screen. Canon provides a tab and tweezers
to fit this screen in Canons…. but, I had to remove the tab fit for fitting in the Viso frame.
Screw plastic!
  • 5 months later...
The Brightscreen is not recommended. It has a hotspot.
One of my Visoflex had a severe screen problem, almost unusable, had all sorts of marks on the inside. I am still not sure about the cause. So I decided to try a Brightscreen Plain Matt (Type 1), as you mentioned that the type 4 had hotspots. Just got it back, looks clear bright focused at infinity. No hotspots.
The folks at Brightscreen said it was the nature of focusing aids that hotspots are created. The type 4 has been discontinued, the type 5 has replaced it, but it most likely still has hotspots.
Wow, you guys are so far ahead of me I almost feel I cannot catch up. I just acquired my first Viso III and a 280 f4.8.
Have not even tried it, but based on this thread it will not be easy to "dial in". I hate to open it up in order to see what shims are in it, not to mention focusing screen issues!
I have an early Visoflex right here on my workbench and haven't dared to try shimming the screen yet. I've worked with shims for very large, aerial photo lenses which was daunting enough. Washington's work inspires me to give it a go.
Can you recommend the proper micrometers? Mine is rather worn away.
