Spyder LensCal
kennedda
Sure. It's apparently both less sophisticated and less expensive than the LensAlign, and fancier and more expensive than the Nikon D70 Focus Chart.
If you've got a dSLR with the ability to set a focus adjustment, either the LensAlign or the Spyder LensCal would be quite useful.
Since that's not a feature of the M, I find the D70 Focus Chart adequate. I use it only to verify a problem once I've discovered it, and then send the offending lens or body off for adjustment.
Both the commercial products look good, and the LensAlign has a number of users on the forum, so there's certainly nothing wrong with trying out either. :)
You could use the LensCal for the M. Though it looks quite small I fear practical use will be a little bit cumbersome: you need two tripods, one for the LensCal, one for the camera. And the usual problems you have getting a focus chart on paper in the right angle to the lens will stay the same or become even more important as it is a lot smaller.
I use a lensalign with my Leica M gear. It has proven just as accurate as with a DSLR system. The only problem is that I cannot correct the front or back focus digitally.
I just send my stuff off to DAG Camera repair. So far my diagnosis with the Lens Align has been correct every time! Very useful!
I recommend using a 1.4 magnifier to focus on the targets too. This ensures the most accurate focus.
You will also need to make sure your camera rangefinder is aligned and to spec to get the most correct reading of lenses.
