First few shots with the M8
neila
I went to a Christening yesterday and am very pleased with how good the M8 is in low light/available light conditions. These shots are pretty much out of the camera.
As noted here before, blacks (amongst other colours) come out purple...
The last shot is my son wearing a jet black shirt with black T shirt underneath and also my wife with a moss green jacket! I know the subject's been done to death here, so I need to experiment a little with processing and also the Leica filters should help...
A quick white-balance would make it easier to see what is going on. Perhaps on the silver game toy in the last picture, and re-applied to the others. Note that in my experience, ACR (haven't tried the CS3 beta) and Lightroom are quite off at the moment, and you would be better off trying C1LE.
I have been playing, but the colours don't really come close.
The first shot here is my wife's jacket from my D-Lux 2, and the second from the M8 (having played with the colours - the shots above are from the camera).
Carsten is right - give C1LE a go, if you haven't already. Download Jamie Roberts' profiles (the very first - stickied - thread in this forum) and that will help considerably. You can fix the white balance within that app, as well.
I went to a World War II remembrance that my 80-year-old father (1st Marine Division) spoke at a couple nights ago and lighting was very difficult. It was in a high school auditorium and I ended up with many too-warm shots, like you've got here. It was also the first time I experiended the magenta-shift in a serious way. Jamie's profile definitely help a lot.
As an aside, it was great fun shooting an event like that with my simple little M8 and Noct, while the official photographer and a couple of serious amateurs lugged their DSLR rigs around. The event photographer used a Nikon D2X and 70-200 and fired a LOT of frames. I'm guessing from the shutter speeds I was getting - shooting primarily at f1 and still having to amp up the ISO to 640 and 1280 - that he was struggling with many of his shots being soft (he couldn't use flash during the presentation). The 70-200VR Nikkor is an outstanding lens (I have one) but it's definitely not a serious-low-light optic.
Jeff
Guest guy_mancuso
Bottom line you will never get the colors absolute until you use a IR cut filter in tungsten light. There are no absolute profiles that can be made to do it , yes even Jamie will tell you the same thing. You can get close but critical is a no cigar without a IR cut filter. You simply have to cut the IR contamination BEFORE it hits the sensor, there is no way to profile it out completely and it would take magic pixel dust to do so and there simply is none. All colors are affected by this not just blacks, All colors under the rainbow will be affected by IR contamination to a certain degree , blues maybe worse than reds , yellows better than greens and so on. So shooting without the IR cut under tungsten which has a huge amount of IR light will always have very ill affects on all color. There is only one way to get around it and that is to eliminate the IR light that comes from your light source BEFORE it hits the sensor. And no i don't own a filter company. LOL
As the saying goes . Otherwise your just pissing into the wind.
Now Jamie and I are good friends and he has worked his tail off to get a good profile going and it does work to a certain degree but it is not absolutely going to fix it all solution. It's more a in a pinch
Don't tell me that is back-ordered from B+W as well!
Is this nearer what you saw?
Ditto, more or less. The problem, essentially, is that two objects that seems to be the same color and tone can reflect IR to very different extents. A profile has no way of knowing how much IR a given part of the subject is reflecting. Jaime has done a great job trying to work around this however.
Cheers,
Sean
And one more ditto--Guy and Sean are both completely correct, of course: the IR cut filter will give you the best colours possible (though there's still more profile work to be done), and in strong IR contamination, you really do need the filters.
You can still save a lot of shots that aren't particularly IR contaminated with a good RAW conversion and profile, or where absolute colour fidelity isn't of prime importance.
So the very worst thing about the shots you're showing here is that they just aren't white balanced at all for--what was it?--tungsten light? Do that first, with a different profile than the supplied one, and you should have a very usable image.
That's a lot of useful information - many thanks for taking the time to post.
Yes Peter, that's pretty close. Guy, thanks for that reassurance on the filter - to be honest I'd prefer a simple solution like a filter rather than having to play too much with Photoshop or other computer programs. As a pure amateur, I like to just crop, add a bit of sharpening and lift the lighting if it needs it.
It was interesting to see quite how much the colours had shifted on black and on my wife's green jacket. If you were taking pictures for a living (as many do here), I'd understand some disappointment.
{Snipped}
Neila--a simple solution like a filter will not fix the white balance, which, as I said, is the very worst part of the shot (and is making the magenta worse). This is the first thing you learn when you take pictures for a living ;)--film or digital, you need to respond appropriately to the kind of light you encounter.
So if you don't want to shoot RAW, or mess around in Photoshop, you should at least learn to set a custom WB in JPEG to have a chance at neutral colour--filter or not!
It's probably me that should go and stand in the corner!
I realise that photography is not easy - but it does strike me as very slightly disappointing that colours are not right straight out of the camera. It's a bit like a brand new car not firing on all cylinders somehow. Anyhoo, the subjects been discussed a dozen times, so I'm not going to rehash it here. I love my Leica and will just have to figure out how to get that cylinder working for me!
Welcome to the wondrous, frustrating world of digital photography...
