Lens extension question
tdtaylor
My questioning mind wants to know, and I know others in the Forum possess the knowledge...
I have a APO 90 Cron (in process of selling) and a 90 Elmarit. When focusing, the Cron extends considerably less than the Elmarit does by a factor of two to three times.
I am suspicious that it has to do with the elements/groups- the Elmarit is 4/4 and the Cron 5/5- but just can't put it together in my mind.
Thanks for humoring me on this subject.
I have a APO 90 Cron (in process of selling) and a 90 Elmarit. When focusing, the Summicron extends considerably less than the Elmarit does by a factor of two to three times.
Impossible.
Could be internal focusing?
Noel
Which these lenses don't have. It may be that the difference in bulk of the lenses gives the impression of different extensions, but it is an optical illusion in that case.
Both have a close focus limit of 1m. None has internal focusing or a floating element. So the change of extension from infinity to 1m should be the same in both cases. With my 90mm Emarit, last version, it is c. 9.5mm. The same with my only other 90mm lens, a v.2 Tele-Elmarit. Go measure.
The old man with the folding ruler
Definitely have a task for tonight when I get home. And I have many folding rulers- I am Architect and Woodworker. I also have the TE, so I'll measure all three. None internally focus.
Thanks,
I stand corrected. All three move 1.0 cm. near to far focus. On a quick look, due to the different spacing of the aperture ring to the focus ring, it does definitely appear the Elmarit moves much farther - that, and as Jaap mentioned, the barrel diameter changes the perspective. And Lars, I didn't use a folding scale- mine are all Imperial, not metric.
Always happy to be corrected by a knowledgable group. As a side note, the focus ring moves smoothly on all three, with just about the same force. So even though the very different diameters and weights, they all feel very similar. Never had them lined up to try together before- and tonight is the last time.
Thanks to all- although I still do not understand why it is 1 cm.
...still do not understand why it is 1 cm.
oh they got an equation for that
x^2 + (2f - s)x + f^2 = 0
"f" is the focal length and "s" is the closest focus distance
  • 2 weeks later...
Hello Everybody,
To put it another way:
For a lens's image size to equal the size of the object it is focussed on the lens's extension must be equal to its focal length. This paradigm is always shown in the following relationship:
Image Size : Object Size. Sometimes also written: Image Size / Object Size.
Never the other way around.
1 : 1 Sometimes also written 1 / 1
For the lens's image size to be 1 / 2 the object's size the extension must be 1 / 2 of the focal length.
1 / 5 the image size requires 1 / 5 the focal length & so on.
A 90mm lens focussing @ 1 meter produces an image 1 / 9 life size.
1 / 9 = 0.111111...... 90mm X 0.111111...... = 10mm = 1 cm extension.
A 135mm lens focussed @ 1.5 meters also produces an image 1 / 9 life size.
1 / 9 = 0.111111...... 135mm X 0.111111...... = 15 mm = 1.5cm extension.
Best Regards,
Michael
Hello # 12,
From the math.
If you place a metric rule on a wall & photograph it w/ a 90mm lens set @ 1 meter & then again w/ a 135mm lens set @ 1.5 meters you will find that if you measure a horizontal portion of the processed negative/slide counting 270mm on the rule it will measure 30mm on the negative.
270 / 30 = 9
The image on the negative is 1 / 9th of the size of the object photographed. Please see my other Post above.
The format is 24mm X 36mm.
24 X 9 = 216 just as 36 X 9 = 324
The coverage @ 1 : 9 is in actuality 216mm X 324mm
The brochure says 220mm X 330mm. Accurate in that you can measure that slightly larger space but not the limit @ the actual focus point of 1 & 1.5 meters respectively.
Best Regards,
Michael
BTW: We are talking about what is recorded on film. Not what is within the frames in the viewfinder. There was a Thread about what frames in viewfinders actually cover not that long ago. There is a range of variation in what frames cover when & how. It is dependent on camera model, focal length of lens, which side of the frame line you are on & so on.
What we are talking about here is actual coverage on film.
I don't know what the parameters are for measuring images created on digital sensors. Someone else may be able to help w/ that information.
The 1 : 9 portion of the relationship will remain 1 : 9 digital or film because that is determined by the lens & its extension. Not by the image capture medium/mechanism.
Thank you Michael. Here's how I read your post: since the product of magnification and focal length is the extension, take the magnification at closest focus from the brochure, and
1/9 X 9cm = 1cm.
Very easy, if you have that additional information.
Hello #12,
Yes.
If they give you a reproduction ratio such as 1 : 9 but not if they give you a size like 220mm X 330mm which is an approximation in an easy to remember form. We have already seen 1 : 9 = 216 X 324 for a format of 24 X 36.
For example if we round off reasonably closely the reproduction ratio for a full frame camera using a 16464 on a Visoflex II, IIa or III with a 65mm Elmar = 1 : 2.4 If we compute 65/2.4 = 27mm, for a 90mm Elmarit = 1 : 3.3 If we compute 90/3.3 = 27mm or for a 135 Tele-Elmar = 1 : 5 If we compute 135/5 = 27mm. Pretty much the extension of the 16464.
Best Regards,
Michael
