help date nickel Elmar 50 ?
I recently received from Rick this Elmar 3,5-5cm / SN 134079 (pics below) which has been CLA'ds by Reinhardt. Can anyone help me date it?
The Wiki has this:
-130463 133506- Elmar 5 cm 1:3.5 (KUP.11-BP+7) 1931 unknown
-144221 151035- Elmar 5 cm 1:3.5 (KUP-7+CHROM-7) 1932 unknown
Where does Nr. 134079 fit into that sequence - looks like it could be either 1931 or 1932 - it does not appear in either year, but is in the middle.
What does KUP mean? Nickel? and KUP.11-BP+7 ? and KUP-7 ?
This is the lens: and fossicking about once again, I found what looks like a black FISON hood + a yellow press on filter with the Nr. 1 engraved on the side rim.
How many stops should I open up when using that filter?
So many questions! Any advice much appreciated.
Your lens should be from 1932 still with "50mm" marking instead of "5cm" but already with the focussing lever at the "7 o' clock" position (for older examples it was at "11 o' clock").
"Kup" was the addendum to the lenses name "Elmar" to indicate that it was coupled with the rangefinder.
Usually with a yellow filter '1' you should open the lens by one aperture or double the shutter time.
P.S.:It's a dangerous lens, for its nickel finish will make you want a nickel black Leica II...
Your lens should be from 1932 still with "50mm" marking instead of "5cm" but already with the focussing lever at the "7 o' clock" position (for older examples it was at "11 o' clock")....
one of the 4000 made this year.
(cannot imagine a bench with 4000 Elmar's on)
:D
