Fermo Posted August 23, 2010 Share #1 Posted August 23, 2010 Advertisement (gone after registration) Hello: I have a problem with the sreen zoom whe I scroll the back wheel. It's seem that became made; doesn't work properlly. Anybody has or have had the same problem? I've chage the firmeware and I went back into de old one, but the problem persist. Any solution or coment? Thankyou in advance. SFM. Link to post Share on other sites More sharing options...
Advertisement Posted August 23, 2010 Posted August 23, 2010 Hi Fermo, Take a look here Problem with the screen zoom. I'm sure you'll find what you were looking for!
trs Posted August 25, 2010 Share #2 Posted August 25, 2010 Yes, had the problem. No solution (I could not find one anyway). Since I really don't zoom through pictures, I did not really bother too much as it worked fine for most of the work I needed to on the screen, navigating menus. When I sent it to NJ for the shutter problem, it came back fixed. Sorry no helping answer except that I had the problem. Link to post Share on other sites More sharing options...
Nicoleica Posted August 25, 2010 Share #3 Posted August 25, 2010 Does the wheel work OK for any other functions? If not, then it could possibly be a bit of dust or other debris has worked its way inside. You might like to try holding the camera upside down, and using a blower to blast some air around the wheel area, while turning the wheel back and forth. You might be lucky and be able to dislodge the offending particle. Otherwise, it probably means a trip to Leica for the camera. Link to post Share on other sites More sharing options...
Fermo Posted August 25, 2010 Author Share #4 Posted August 25, 2010 Thankyou, Tanka and Nicole. The problem seems to be as Tanka describes. I miss I can not zoom the screen to see the dust on the sensor. But I'll need the camera for a trip in octuber and I'll send to repair after it. Thankyou. SFM. Link to post Share on other sites More sharing options...
jaapv Posted August 25, 2010 Share #5 Posted August 25, 2010 Dust on the sensor is no reason to send it in, you might consider cleaning it before you leave. The scroll wheel problem is a known defect, that should be sent in. Link to post Share on other sites More sharing options...
A. Cheng Posted August 26, 2010 Share #6 Posted August 26, 2010 I had the same problem. Not just it didn't zoom but couldn't scroll menu neither. I 'tolerated' it somehow for over a month (as it didn't affect shooting and the arrows work for menu up-downs). Tried similar way Nicole suggests but failed. Finally I sent it to Schmidt Marketing in Hong Kong on a Friday and got a call to take it back on the Monday next:). Must say they are really efficient. Link to post Share on other sites More sharing options...
Fermo Posted August 26, 2010 Author Share #7 Posted August 26, 2010 Advertisement (gone after registration) Thank you for your tips. I will send finally the camera to Solms. The service repair in Spain send all the cameras to Solms once a week. Unfortunately they take at least four weeks in return the camera back. SFM. Link to post Share on other sites More sharing options...
