ColdDuckTime Posted August 9, 2010 Share #1 Â Posted August 9, 2010 Advertisement (gone after registration) Has anyone else had this problem with the M8? It's got progressively worse since I bought it and now its pretty much impossible to move. Are there any known fixes to this problem? or am I just going to have to send it to Leica? Thanks. Link to post Share on other sites More sharing options...
Advertisement Posted August 9, 2010 Posted August 9, 2010 Hi ColdDuckTime, Take a look here Stiff Power Switch. I'm sure you'll find what you were looking for!
jaapv Posted August 10, 2010 Share #2 Â Posted August 10, 2010 That is a new one - up to now the complaints were that it moved to easily - and dozens of them. Yes, it sounds like something like sand worked its way in there and you will have to send it in. Link to post Share on other sites More sharing options...
Nicoleica Posted August 10, 2010 Share #3 Â Posted August 10, 2010 I never had any problems with my M8. Mine actually had a switch that was perfect, not too loose, and not too stiff. However, I did have a similar problem with my F3. The power switch became so stiff that I was almost afraid to use it. Before sending it off for repair, I decided to risk cleaning around the switch area with some lens cleaner solution. Working on the theory that if it was gentle enough to clean lenses, it was unlikely to eat my camera. (The particular brand that I used was T'nB in this case. It came as a part of a cleaning kit that I had bought.) I let the solution seep under the switch (Just a few drops.) and waited a short while. Whatever gunk was causing the switch to stick was dissolved/rinsed away, and the switch now functions as good as new. If your camera is out of warrantee, itt might be worth trying this before sending your camera to Solms. Link to post Share on other sites More sharing options...
jaapv Posted August 10, 2010 Share #4 Â Posted August 10, 2010 If you are going to do that, Nicole, you might as well use a drop of WD40. Link to post Share on other sites More sharing options...
Nicoleica Posted August 10, 2010 Share #5 Â Posted August 10, 2010 If you are going to do that, Nicole, you might as well use a drop of WD40. Â I know that you wrote that with a smile Jaap, but the lens cleaner is a mild solvent that evaporates cleanly. WD40 tends to leave an oily residue that I didn't want in my camera. (I do use that for most other things though.) Link to post Share on other sites More sharing options...
jaapv Posted August 10, 2010 Share #6 Â Posted August 10, 2010 Actually WD40 is an electrical contact spray and cleaning spray as well, so it was not wholly tongue-in-cheek. Link to post Share on other sites More sharing options...
garygsandhu Posted August 10, 2010 Share #7 Â Posted August 10, 2010 Advertisement (gone after registration) Don't use wd40 anywhere near the camera! I destroyed a contax T this way. It seeps in, and the hydrocarbon may act as a plastic solvent. Perhaps you can use compressed air. Not sure about naptha. Link to post Share on other sites More sharing options...
jaapv Posted August 10, 2010 Share #8 Â Posted August 10, 2010 Ok- consider the idea stricken from the record! Link to post Share on other sites More sharing options...
UliWer Posted August 10, 2010 Share #9 Â Posted August 10, 2010 Has anyone else had this problem with the M8? It's got progressively worse since I bought it and now its pretty much impossible to move. Are there any known fixes to this problem? or am I just going to have to send it to Leica? Thanks. Â Mine went rather stiff for some time and even the release button didn't move properly, i.e. I couldn't find the point to save the exposure measurements precisely but released the shutter often when I didn't want to. Â Perhaps this was caused by dust, sand and/or sweat on the switch. Â After I applied some dry cleaning and some exercizing the switch without a battery, it was well again like new. Link to post Share on other sites More sharing options...
bocaburger Posted August 10, 2010 Share #10 Â Posted August 10, 2010 I haven't had the problem yet with my M8, but my M7's switch got a little sticky. I wrapped a length of unwaxed dental floss around in the gap under the switch and pulled it back out. Got whatever out was under there and solved the problem. Gently or you could snap the floss off stuck in there. Link to post Share on other sites More sharing options...
wstotler Posted August 10, 2010 Share #11 Â Posted August 10, 2010 I wrapped a length of unwaxed dental floss around in the gap under the switch and pulled it back out. Got whatever out was under there and solved the problem. Â Floss your Leica? LOL. Love it--simple, effective. Cheers! Will Link to post Share on other sites More sharing options...
2Bébèrt Posted August 11, 2010 Share #12  Posted August 11, 2010 Has anyone else had this problem with the M8? It's got progressively worse since I bought it and now its pretty much impossible to move. Are there any known fixes to this problem? or am I just going to have to send it to Leica? Thanks.  Same on my power switch caused by water infiltration witch set off some oxidation in the switch. (a few snowflakes had melted on and around the switch) Also had bad battery life and strange behaving release moments. Leica AG would not repair it, (was even still under warranty) unless I payed €300 just to get an estimate of the total repair bill.  So, I fixed it myself — disassembling the M8, cleaning the switch and reassembling — (thanks to marknorton's threat http://www.l-camera-forum.com/leica-forum/leica-m8-forum/21331-anatomy-leica-m8.html) and now, one year later, still works fine. Link to post Share on other sites More sharing options...
jaapv Posted August 11, 2010 Share #13 Â Posted August 11, 2010 Well, if it was caused by water it would not have been for the guaranty but for the insurance. But well done. Link to post Share on other sites More sharing options...
epand56 Posted August 15, 2010 Share #14 Â Posted August 15, 2010 I never had any problems with my M8. Mine actually had a switch that was perfect, not too loose, and not too stiff. Â +1 Link to post Share on other sites More sharing options...
