Leica M8 LCD malfunction
tecumseh
While on a trip to italy my M8's screen is now only displaying a white frame. On one occasion it went back to the normal screen but is now just white again. If you angle the screen you can just about read some of the menu information. Has this happened to anyone else? Camera is still on warranty but wonder if this is a common fault?
If you can see some data at certain angles, have you tried setting the screen brightness down? (This is on the main menu.) It's possible that somehow it's been set to super-bright, and a change of the level may correct the situation. :)
Otherwise, it sounds like your camera is in need of a short holiday in Solms. :(
