Leitz Leicina
Does anyone know anything about the Leitz Leicina RT 1 camera? I also enjoy taking real movies with film and I bought this camera through E-Bay. Camera ia MINT and works perfect but there is a small slide switch on the left side, near the top of the camera and near the trigger release. I have tried to use this switch in numerous ways and nothing seems to change. It does look factory installed and the user manual says nothing about it. Also I need a new rubber lens hood and the thread is 54 mm. Very odd size and I can't find a replacement for this. ANY help at all with these two small problems would be greatly appreciated.
The manual says nothing about it? Odd - can you post a picture of the switch? As to filter size - 54mm is Series VII and you should be able to find a 54mm to 55mm adapter on eBay. I'd do the search for you but my wife is ringing the supper bell and I have to run like mad.......
Best,
Jan
Just in case here is a photo of the camera. Again there is nothing shown or mentioned in the user manual. I have both the English and German version and they show nothing. Thanks
Ok, so....
The slide switch has nothing to do with keeping the camera running. If I turn the TOP release clockwise and depress the button down it will keep running. I tried moving the switch back and forth and there were no changes. This is a tough one. I hope someone can help!!!
I have looked at several pictures of the camera which I could find in the web. None has that switch. Also, the switch does not look entirely straight on your camera, as far as I can tell at the given resolution. My guess would be that your camera has been modified. In order to find out what the switch does, you'd probably have the open the camera and analyse the wires leading from the switch. Can the back side of the switch be seen through the battery compartment or the film cassette housing?
Hi! I can not see anything inside the film compartment. There is a plastic shield so no views of the inside of the camera is possible. The switch does seem straight but of course the photo is not perfect. If I can not get an answer from anyone I might have the camera serviced and once that is done the servive person can hopefully tell me what is going on. This is frustrating! Thanks anyhow!!!
On the other hand, you might just ignore the switch. I own many devices with switches I never touch, even if I can remember their functions. As long as all the functions work according to the manual, your Leicina is just a Leicina with an extra switch.
Of course, If your curiosity doesn't let you sleep, you might look for a repair person who will open the camera for you and trace the wiring.
Hi Philipp! Okay, Maybe I will just use the camera for a bit and then when its 10 degrees outside I will send the camera to a shop for a "going over" and then they can trace the switch function. Thanks!
Sorry... trivial question: are really STILL available the Super 8 film cassettes ? I thought they wern't anymore around...
Indeed they are Kodak Super 8 Film - Telescopes UK: Telescopes & Telescope Accessories in your only London shop
There's another online shop (can't find it right now) that sell all sorts of home film movie equipment and supplies.
<snip>I have looked at several pictures of the camera which I could find in the web. None has that switch. My guess would be that your camera has been modified.
...furthermore, there is an extra black "button" below the frame speed selector (in the 5 o'clock position). All the images and instruction manuals I have seen of this model (Leitz Leicina Super RT1) clearly feature the three black "buttons" seen above the selector but no additional ones below.
Intriguing, non? The plot thickens.
Some S8-Cameras has been modified to synchronize Sound (for example Quarz or Synton). Perhaps the Switch ist build in subsequent for this purpose.
Edit: You can see the switch here too:
http://cgi.ebay.at/LEITZ-LEICINA-SUPER-RT-1-PROFESSIONAL-SUPER-8-CAMERA-/360257963327
Olybold
...great find, Olybold - all we need now is for someone to confirm your supposition. Come on, Leica folks, there must be one or two Leicina hardnuts out there. :D
