jtannen Posted June 23, 2010 Share #1 Posted June 23, 2010 Advertisement (gone after registration) Hello, I recently purchased a lovely M8.2 and would greatly appreciate any advice. I know this has been discussed quite a bit, but regarding framelines only, do folks recommend coding a pre-asph 35mm Summicron lens? Thanks so much! Link to post Share on other sites More sharing options...
Advertisement Posted June 23, 2010 Posted June 23, 2010 Hi jtannen, Take a look here M8 framelines and pre-asph coding. I'm sure you'll find what you were looking for!
andybarton Posted June 23, 2010 Share #2 Posted June 23, 2010 Welcome to the forum - first post 5 1/2 years after joining must qualify you for some sort of prize Coding has no affect on framelines. Link to post Share on other sites More sharing options...
tecumseh Posted June 23, 2010 Share #3 Posted June 23, 2010 I coded my lenses with the M Coding Kit (essentially £80 for a magic marker and a stencil) and it made little difference beyond telling me the focal length in EXIF data. I wouldn't bother but I could sell you the kit for the knock down price of £40 (for a magic marker and a stencil...) so you can see it not making a difference for yourself! Link to post Share on other sites More sharing options...
bocaburger Posted June 23, 2010 Share #4 Posted June 23, 2010 If you use an IR filter (and you probably will want to) you can get some greenish color cast in the corners with wideangle lenses, which if they're coded the firmware works its magic and gets rid of that cast (even in DNG). Otherwise you can do it with 3rd party software in post but it's an added and unnecessary step. Some say 35mm lenses are above the cut-off point for the green corners, others disagree. I coded my 35's without doing any testing. I didn't use any coder kit or magic marker, I marked off the sensor borders on the outer body flange and then transferred the markings to the lens, divvied the area up into six segments and ground in little recesses for just the black coding marks, then filled them with black auto touchup paint. Works perfectly and won't wear off...but I don't advocate this for anyone who doesn't have a steady hand with a Dreml (or who is concerned with keeping his lenses strictly OEM. My older 35 Cron is not on Leica's codable list, and it's far from mint anyway). Link to post Share on other sites More sharing options...
luigi bertolotti Posted June 23, 2010 Share #5 Posted June 23, 2010 Why do you specify "regards framelines only" ? Any Summicron 35 makes the correct framelines to appear in the viewfinder... even the goggled versions. Afaik the only 35 that turns up uncorrect framelines is the very first Summaron 3,5. Anyway... I'd suggest coding for the above quoted UVIR filter issue. Link to post Share on other sites More sharing options...
jaapv Posted June 23, 2010 Share #6 Posted June 23, 2010 The goggled Summaron 35 will gve the correct framelines Link to post Share on other sites More sharing options...
luigi bertolotti Posted June 24, 2010 Share #7 Posted June 24, 2010 Advertisement (gone after registration) The goggled Summaron 35 will gve the correct framelines Right, but (hair - splitting) the "very first" I quoted was ungoggled... Link to post Share on other sites More sharing options...
jaapv Posted June 24, 2010 Share #8 Posted June 24, 2010 Now that we have that sorted.... Link to post Share on other sites More sharing options...
