Completed dead My M9
varintornkamala
Due to the last posted question about noise in low iso and more problem on my m9 . Now today I try to take shot to proof the iso is it jump itself because the wheel jogging not work for awhile. But when I turn on to day , it showed on monitor (pic 1 ) to reset the folder and follow by other statement card full ( pic2) and follow by cannot do anything more , take picture it's silent cannot done, goto menu cannot. I must to turn off and on again then it can use menu or set . I try to change new card , off battery, reset folder , so the result was same cannot shot the picture.
Anyone have suggestion or comment please tell me. My dealer in Thailand they said nothing, have to see my m9 and send to Germany , wait , but I just bought for a couple months and it had problem ( other case ) since I received its first date.
Turn off your camera, remove the battery and memory card.
With both removed, replace the cover.
Turn on your camera and press the shutter button. This will draw down any possible remaining current in your camera.
Charge your battery 100%
Make sure your memory card is one that Leica approves and has tested.
Replace the battery and card. Turn on your camera and see if it works now.
If you still have the same issues, ask your dealer to FedEx or DHL it to Germany for quick repair or replacement. I hope this won't be necessary.
Good Luck.
Good Luck.
Thank you very much friend, The all your suggestion has done many many time and now the m9 transforms to paper holder the dealer has look it and smile smile ,bye bye my m9 . it's total lost now.
This is a fault that is a cooperation between a bad camera design and a faulty battery.
Get the dealer to give you a new battery, charge it to 100%, insert it, and the camera may restart.
Every battery won't work, you may need several.
Edmund
This is probably a stupid question, but did you try resetting the entire camera to factory settings while it's responsive?
Another try would be to re-apply the firmware, new SD-card as battery, as has being said already.
Good luck and best,
Michael
1. reformat the card in the computer
2. Put it in the camera . Set file numbering to continuous in the menu and reformat the card in the camera.
3. Return the card to the computer, change the number of the DCIM folder by changing the first 9 to 1
4. Put in the camera, take one image, and reformat.
Somebody used a card with a very high file number in your camera, and it has reached the end of its numbering, that is why it asks for a reset of the file number.
Yes, I think the fact Leica have given you a back-to-front camera is a real bonus, the collectors will love it and will not mind the fact it's stopped taking pictures.
I LOL'ed.
Good luck and best,
Michael
Thank you Michael all your suggestion had made reset , re firmware , new sd, nothing better , now my dealer received camera and send to Germany when they looked and tried nothing happen now , they agreed that m9 completed dead and sent information to leica . It's factory fault .
I hope you get your M9 fixed soon. You could ask your dealer to send your camera to Leica HongKong instead. I had a problem with my sensor board, and my dealer gave me an option of sending it to Hongkong or to Germany. And since I'm in Asia, sending it to Hongkong is much closer, and takes much less time. So I'd suggest you doing that.
I got my M9 back after 10 days.
