kivis Posted May 7, 2010 Share #1 Posted May 7, 2010 Advertisement (gone after registration) Getting a nice used M8 next week. I already have a Voigtlander 35/1.2 which I want to mate to the M8. What coding must I do and how to, to the CV 35? Link to post Share on other sites More sharing options...
Advertisement Posted May 7, 2010 Posted May 7, 2010 Hi kivis, Take a look here M8 newbie question, coding CV lenses. I'm sure you'll find what you were looking for!
jsrockit Posted May 7, 2010 Share #2 Posted May 7, 2010 You probably won't have to code it. I don't code my 35mm voigtlander and I don't see any ill effects. Link to post Share on other sites More sharing options...
ampguy Posted May 7, 2010 Share #3 Posted May 7, 2010 Coding will only affect the EXIF info in your files with a 35mm. Try a temp. d-coder from Bo Lorentzen if you have wider, you may determine you don't want to code wider lenses, they sometimes over-correct cyan corner shift. Link to post Share on other sites More sharing options...
garypasz Posted May 9, 2010 Share #4 Posted May 9, 2010 Getting a nice used M8 next week. I already have a Voigtlander 35/1.2 which I want to mate to the M8. What coding must I do and how to, to the CV 35? If you do go with coding your lens check out this DIY i've seen on ebay.(buts a bit pricy) Coder kit To DIY 6-bit code on Leica M lens fit M8.2/M9 - eBay Other, Lens Accessories, Lenses Filters, Cameras Photo. (end time 25-May-10 14:39:46 AEST) Link to post Share on other sites More sharing options...
