Fixing focus shift?!
Guest willjanurgucken2000
Hi!
I've an 35mm CV on a M8. Surprise surprise, it has a appreciable focus shift.
but ok, it was only from f 2.8 till f4. At 5.6 it was away (depth of field), at f 1.4 the lens is tack sharp. so long, i was happy.
then by changing the lens I dropped the 35mm and it was heavily out of focus. I brought it to my local repairman who fixed the lens. He told me that he fixed the back focus (from the crash) and also the focus shift. now the lens does not shift any more - really. for the first time in my life I tested a lens with a tripod and taking pictures from walls, bookcases.... and yeah the focus shift is away.
BUT: If I focus now on a subject far away (infinity) the rangefinder says one millimeter before infinity on the lens, that its sharp. do you understand what I try to say (sorry, my english is fu**ing bad).
Is this normal, bad, or what are the consequences. important is, that the focus shift between 2.8 und 4 is away...
regards
will
Focus shift correction is always a compromise. It seems the technician adjusted the lens to be more or less within DOF throughout the range, and I think you will have to accept the discrepancy at infinity if you are happy with that.. It is not my favorite adjustment, I prefer a lens to be spot-on wide open, which means it will be off between f2 and 5.6, after which DOF kicks in, but that is just me.
thank you for the fast answer.
It is still tack sharp wide open. It only seems that the focus shift has been forwarded to f8 and f11, so that the DOF covers the focus shift. it's the only way how I can explaine it to me...
from up f 1.4 I cant see any shift and therefore it is still sharp...
and I also can't notice any difference in the infinity position.
Well, at this stage I'd think that the best way to fix a lens' focus shift is dropping it and have it repaired. As an added benefit one ends with an enhanced lens that can focus beyond infinity :-)
Apart from kidding, my suggestion is to keep the lens as is. Probably the focus shift is still there, but the drop and the fix somehow "shifted" it at infinity. If you can focus at all distances within the cam's reach it's OK. After all the annoyance comes only from the awareness that the rangefinder's and lens barrel's infinities do not exactly match, but as long as the pictures are sharp why bothering yourself?
Cheers,
Bruno
yes, if your lens was adjusted to front-focus slightly to compensate for focus shift, the discrepancy in the scale will be as you described.
