Ivar B Posted April 21, 2010 Share #1 Â Posted April 21, 2010 Advertisement (gone after registration) Does anyone have any experience with the Zeiss 4.5/21 on Leica M8? I know that this lens does not work well with the M9, as its optical construction is such that the rear lens element comes even closer to the sensor than is the case with other Zeiss or Leica lenses and the sensor cannot handle it. Link to post Share on other sites More sharing options...
Advertisement Posted April 21, 2010 Posted April 21, 2010 Hi Ivar B, Take a look here Zeiss ZM Biogon-C 4.5/21 on Leica M8. I'm sure you'll find what you were looking for!
daleeman Posted April 21, 2010 Share #2 Â Posted April 21, 2010 Does anyone have any experience with the Zeiss 4.5/21 on Leica M8? I know that this lens does not work well with the M9, as its optical construction is such that the rear lens element comes even closer to the sensor than is the case with other Zeiss or Leica lenses and the sensor cannot handle it. Â I have the 2.8 21mm lens and it is a gem. If you are about to buy the Zeiss 21mm then do the 2.8. The price point difference is not so bad that one could not justify buying the 2.8. It works well on my 8.2 and have read many times it is fine on the M9. Lee Link to post Share on other sites More sharing options...
cbretteville Posted April 21, 2010 Share #3  Posted April 21, 2010 Here are a couple of old threads that might be worth a look Ivar.  http://www.l-camera-forum.com/leica-forum/leica-m8-forum/55973-zeiss-biogon-21-f-4-5-a.html http://www.l-camera-forum.com/leica-forum/leica-m8-forum/72315-zeiss-21-biogon-zm-lenses-4-a.html  Carl Link to post Share on other sites More sharing options...
thompsonkirk Posted April 21, 2010 Share #4  Posted April 21, 2010 I agree with Lee. I use the Zeiss 21mm 2.8 on M8u & fairly often have occasion to use it wide open. The price jump from f4 to 2.8 is smaller than you'd expect.  Some folks (like me) have shied away from Zeiss lenses because of their strong contrast. But the 21 2.8 seems different – it's not so contrasty.  Kirk Link to post Share on other sites More sharing options...
Kittyphoto Posted April 22, 2010 Share #5 Â Posted April 22, 2010 Does anyone have any experience with the Zeiss 4.5/21 on Leica M8? I know that this lens does not work well with the M9, as its optical construction is such that the rear lens element comes even closer to the sensor than is the case with other Zeiss or Leica lenses and the sensor cannot handle it. Â Zeiss 4.5/21 work best on M8. Well balance, light and small, smooth focus, no distortion. Contrast is a bit high. One of the sharpest lens for M8 even at widest f4.5. No color cast at the edge on M8 unlike M9. Link to post Share on other sites More sharing options...
antonio-p Posted May 4, 2024 Share #6 Â Posted May 4, 2024 On 4/22/2010 at 8:39 AM, Kittyphoto said: Â Zeiss 4.5/21 work best on M8. Well balance, light and small, smooth focus, no distortion. Contrast is a bit high. One of the sharpest lens for M8 even at widest f4.5. No color cast at the edge on M8 unlike M9. Are you sure that using it on the Leica M8 you won't have the problem of color cast at the edges and corners? Link to post Share on other sites More sharing options...
chris_livsey Posted May 5, 2024 Share #7  Posted May 5, 2024 Advertisement (gone after registration) The "better" performance on the M8 is largely down to the crop factor over the full frame M9, for what it's worth I think the f4.5 is my preference. Link to post Share on other sites More sharing options...
