35mm f3.5 Summaron values
Guest JoanMarianne
Guest JoanMarianne
I note that a 1952-made 35mm f3.5 Summaron (presumably the first, E36, version) has sold for over £400 Sterling on an Internet auction site. Is this an indication of the performance of this particular lens - or of its rarity? I have just had a 1953 example of the same type serviced and the results, with black-and-white film, are impressive and distinctive in a way which does not feature in more modern lenses where sharpness and contrast seem to be the only criteria. (I paid less than £400 for my lens plus a IIIf Black-Dial body!)
x
£ 400 seems to me a lot of money for the A36 Summaron... it's indeed very common, even if the Summaron 35 F3,5, in itself has an interesting history ;) (see another thread here...) : I would be curios to see the item sold for that amount... can you give details on the auction site ? Maybe it has something uncommon... or it is in superb conditions and with lot of add-ons appreciated by collectors (box-case-sales documents- hood-finder-caps...)
I think I found the lens referred to. It's the later type but a screw fit lens which would orginally have had a bayonet mount attached and screwed on.
The price is high (about twice as high!) for the type of lens but obviously the mount detail was of sufficient interest to a couple of collectors to bid the price up.
James, this model, if we speak about the lens # 1005777, never has been build in bayonet mount.
The price reached is only the result from a battle from two bidders (as sometimes occurs on Ebay).
eBay UK Item Bid History
JC,
Here's the one I think is being referred to Leitz 3.5cm f/2.8 Summaron lens for Leica camera on eBay (end time 11-Mar-10 20:05:03 GMT)s
Edit - Ah, I just saw your e bay link. Indeed a very high price for that lens! As you say more likely the outcome of a battle between rival bidders, fortunate for the seller though.
Wow... I never bought on ebay and didn't know bid histories were available : really funny the above one... :p... incredible such a heated battle on a common item... surely the seller is the real winner: I can only think that the two contenders were collectors with some love affair with certains numbers... :D... "777" at the end is fine... the BEASTY "666" could had doubled again the price... :D
JC,
The 2,8 you refer to is similar to one I have (1.628.xxx), which too has the tiny hole to fit the factory-installed BM adapter... I do not regard this as a significant value adder... but someone can have a different opinion: btw, my one focuses to 0,65, not 0,7, making it a real "bastard" ;)
Guest maddoc2003jp
Wow ! :eek: I have a similar 3.5cm 1:3.5 Summaron in screwmount, SN 889xxx with a similar bubble-case and paid about $225 for it (end of 2008). Have prices gone up that much ?
Both sold for way above their typical values though :confused:
Hi James,
I use to have a general survey on market/values and in the last months/year the 2.8 Summaron is relatively stable around 400/450 euros in mint condition.
an original SM is around 700/750 euros always in mint condition.
Now this one you are refering with the double mount, complete, can be 600 euros valued, always in mint condition.
Please have a look
here
Guest JoanMarianne
Interestingly, a 2.8 Summaron has surfaced on Ebay where the owner has noticed that it a screwmount version intended for use with a bayonet adapter. Apparently it can be fitted to a screwmount body but will not focus correctly.
This happens if the lens, originally, had the goggles for use on M3.... as far as I know, if it was a model for M2, ungoggled, removal of the BM adapter fitted at the factory does not affect focusing on a screwmount body (my only experience about is the "BM/SM" Super Angulon 21 f4 : adapter fitted with a tiny screw - removed - ok on screwmount)
