D2 - SF24 Flash?
wilfredo
I'm considering purchasing a Leica SF 24 flash for use with my D2. Any thoughts? Sample shots? I hardly ever use the flash on the D2 but when I do, I'm not very pleased with the results so I'm wondering if this overpriced flash will make a difference?
That aside, I've grown very fond of this camera.
SF24 and Digilux 2 were designed to work together. All the functions of the one couple with the other.
I seldom use external flash with the Digilux 2 because I find the bounce facility of the built-in flash very useful.
If you need more power, the SF24 works excellently, and can be used on M8, M9 etc as well, though not with full functionality on Digilux 3 or D-Luxes.
Yeah, I had the same problem till I figured out I had to remove the hood when using the 45 degree position, particularly for wide-angle shots. :o
An accessory to consider for the SF24D is the Leica Goodies "sfill" diffusion screen (http://www.leicagoodies.com/sfill.html). I've seen several favorable mentions of it here, though I've never bought it. The general suggestion is to use the wide-angle adapter with the sfill for the softest illumination.
Howard,
Thanks for the tip.
Does anyone have any D2 - SF24 photos they care to post? They don't have to be masterpieces, just something that will give us an idea of how this flash works on the D2.
Thanks!
No brave souls? I promise my aim is not
to critique I would just like to see something before spending the money.
Thanks
Actually, I have one and have never had it on the camera.
Regarding the built in flash, check this out:
http://www.johnthawley.com/journal/2009/7/15/bounce-with-me.html
John,
Thank you. I will try this. From the looks of it, the SF24 does not have a lot of fans. This thread has not generated any interest. I'm going to try your method before going out and spending any money. Where did you buy the styrene stock?
Wilfredo, I've used the SF24 with both my D2 and M8. It works fine with both. Big improvement is the ability to put on an extension cord (Nikon SC-17, in my case) and use off camera for improved modeling on the light. Need to go through by files to pick out some with the SF24. Only downside is that it's a small flash and doesn't produce a lot of light. On the other hand it's small enough and light enough you can use it as a take anywhere to supplement the on-camera. For heavy-duty flash needs I have a Metz 54-MZ4 with a 3502 M4 adapter.
I've used the SF24 with the SFILL on my D2 for ages now with excellent results. I stopped using the TTL feature as it ate (the SF24's) batteries quicker with double flash. Manual now, plus I know the camera well . . .
