Red Edge - Red Middle?
TacTZilla
  • Replies 41
  • Created
  • Last Reply
... Also, his lens the 50lux I believe corrects CAs using special apo glass (not sure about that tho)....
You're right to say you're not sure. Such a thing as "special apo glass" doesn't exist. And the 50 Summilux isn't an apochromatic design.
It's a common misperception that APO lenses will not show chromatic aberration. The term "apochromatic" when used with lenses doesn't have a truly official status, but is generally used to indicate that all the spectrum is brought into focus at the same point. An apochromatic lens can still show LoCA, because the CA you are seeing is actually on either side of the plane of focus....
Jeff, you're correct that "apochromatic" as used in today's marketing speak hasn't a formal definition. Technically, it isn't possible to bring the full spectrum into a single focus. It suffices to bring three widely-spaced colors to the same focal point; to completely correct for spherical aberration at two widely-spaced colors; and to completely correct for coma at one.
Check Defining Apochromatism for a clear explanation from the year 2003. Of course, other lens designers' definitions will be more or less exact than Back's, since as you say, the modern definition has become quite flexible.
