Using square hood on old Summicron 35mm?
nickmeertens
x
You get much better shading if you use an old rectangular hood instead.:)
With the rectangular plastic 35mm hoods, I think you just need to file off the little lugs on the hood that make sure it's lined up with the field of view.
The small rectangular plastic hood for the 28 ASPH f/2.8 and 35 f/2 ASPH or v.4 pre-ASPH also fits the pre-ASPH Summilux (without removing the alignment tabs, although there are no notches for them to lock into, so the hood can rotate by accident).
Basically, the clip-on Leica shades for E39 lenses are pretty interchangeable - the grooves on the lenses that the clips catch hold of are in the same position for 35, 50 'cron, 90 Elmarit/TeleElmarit, and 135 Elmar lenses. I've swapped around 35, 50, 90 and 135 clip-on shades and they all physically fit (leaving aside questions of vignetting).
So any 35 that will take the old 1960s/70s round metal clip-on hoods should also accept the plastic clip-on shades.
