6-bit code
jjonsalt
x
I've been wondering about this too, having just acquired an old 28mm
Why?
Because it allows M8 firmware to correct the side effect of the UVIR filter ("cyan drift") at the edges and corners : this is much more significant for wideangles, for it's due to the angles at which light crosses the UVIR glass - higher for wideangles. Around 50 mm and over is not significant.
BTW... if the 28 you acquired is really "old" (first series of Elmarits) can be that coding is impossible.
Yes, it is important for lenses which focal length is 35mm and below. Above 35mm, the impact on IQ is marginal, and the main thing you'll be missing is the lens data in the file exif.
Whether you want to pay for it or not is your choice: alternatives include DYI (there have been numerous threads on this forum on how to do it) and a small application called Cornerfix, developed by a forum member.
A quick forum search should return plenty of hits and you should be able to make an informed decision.
FWIW, I had all my Leica lenses coded by Leica and hand-coded all my CV lenses.
Because it allows M8 firmware to correct the side effect of the UVIR filter ("cyan drift") at the edges and corners : this is much more significant for wideangles, for it's due to the angles at which light crosses the UVIR glass - higher for wideangles. Around 50 mm and over is not significant..
Thanks for the info. Does the correction get applied if you shoot RAW, or just on JPEG files?
The downside is that the ink will rub off pretty soon. You could make your own indentations , but sending the lens to one of the various camera technicians that offer this service is better and not that expensive.
I can really appreciate the difference this might make on an M9, but with the M8 effectively cropping out the edges of the image anyway, does it really make a big difference? Has anyone actually got examples of original then coded images taken for comparison? I'd be really interested to see some.
Thanks
Oh I see. Thanks for the response. As I understand it the IR filter is necessary, particularly, to stop black synthetic fabrics from showing up as a dark red. Presumably the IR filter wouldn't be required if B&W images were what was wanted?
Thanks again, jc
It has been discussed before - it is not just blacks. Colours are off all over the spectrum, most noticeable chlorophyl (green foliage) and heamoglobin (caucasian skin) In B&W it will lighten up the shadows, which may be benificial, and in all cases there will be a very small loss of shapness.
