Guest purpledot Posted December 25, 2009 Share #1 Posted December 25, 2009 Advertisement (gone after registration) Does anybody know if these two cameras use the same battery? Cheers, Purpledot Link to post Share on other sites More sharing options...
Advertisement Posted December 25, 2009 Posted December 25, 2009 Hi Guest purpledot, Take a look here Battery Digilux 2 = V-Lux 1 ? . I'm sure you'll find what you were looking for!
stuny Posted December 25, 2009 Share #2 Posted December 25, 2009 The V-Lux uses the same battery with additional amp-hour rating. They are interchageable. Link to post Share on other sites More sharing options...
Guest purpledot Posted December 25, 2009 Share #3 Posted December 25, 2009 The V-Lux uses the same battery with additional amp-hour rating. They are interchageable. Excellent! Thanks a lot. One more obstacle removed to getting a new camera Link to post Share on other sites More sharing options...
doubice Posted December 25, 2009 Share #4 Posted December 25, 2009 Does anybody know if these two cameras use the same battery? Cheers, Purpledot The V-Lux uses the same battery with additional amp-hour rating. They are interchageable. Sorry - they are not interchangeable. The Digilux 2 takes a Panasonic CGR-602A (Leica BP-DC1) battery, the V-Lux 1 (same as the Panasonic DMC-FZ50) takes a Panasonic CGR-006A. The Digilux 2 battery is bigger, with completely different contact locations. I found this site when getting the correct part numbers: http://www.eastcoastphoto.com/nav/bfinder.asp Best, Jan Link to post Share on other sites More sharing options...
Guest purpledot Posted December 25, 2009 Share #5 Posted December 25, 2009 Sorry - they are not interchangeable. The Digilux 2 takes a Panasonic CGR-602A (Leica BP-DC1) battery, the V-Lux 1 (same as the Panasonic DMC-FZ50) takes a Panasonic CGR-006A. The Digilux 2 battery is bigger, with completely different contact locations. I found this site when getting the correct part numbers: Battery Finder at EastCoastPhoto.com Best, Jan Oops - thanks for the update. That's a handy reference. Link to post Share on other sites More sharing options...
stuny Posted December 26, 2009 Share #6 Posted December 26, 2009 Purple - Sorry. When comparing batteries with a V-Lux owning friend I failed to look closely enough. Link to post Share on other sites More sharing options...
Guest purpledot Posted December 31, 2009 Share #7 Posted December 31, 2009 Advertisement (gone after registration) Purple - Sorry. When comparing batteries with a V-Lux owning friend I failed to look closely enough. No problem I bought it anyway - and will write a bit about it later. Link to post Share on other sites More sharing options...
