Current Product 75 vs. 90 Asph 2.0's, IQ?
novice9
I am wondering what folks think about the relative IQ produced by these two lenses? They both get great accolades, but the 75 would appear to be a bit new design (inclusion of floating elements that I don't believe are in the 90, etc., more elements). (Please note that I'm not asking about the relative usefulness of these focal lengths.) Any insights would be much appreciated.
Assuming you are refering to the Summicron 75 asph and the Summicron 90 apo asph, those two lenses are certainly among the best lenses ever produced in their respective focal length. There is no perceivable difference in IQ in my opinion, at least not with regard to contrast, sharpness and resolution. Bokeh may be somewhat different, some say the 90 apo asph is a bit harsh in that respect, but I have always found my copy to be very pleasing. You can't go wrong with either of them, the choice just depends on personal preference.
Andy
Thanks much Andy. And yes, sorry for not being more clear, I am talking about the 2 current production summicrons. Personally, I like both focal lengths alot on a FF camera, they both seem to fall right in the heart of what I like to shoot, probably because I do a lot of portraits. Thx. t.
I have owned both and prefer the 75 cron over the 90 AA if I had to choose one. The 75 cron also focuses down to 0.7M and actually has a higher reproduction ratio than the 90. However, I do know that some others prefer the 90. The 75 seems to be easier to focus with a shorter focus throw as well.
Good luck.
I have both and both are superb, although I would give an edge to the 75 in sharpness and microcontrast. It's very slight, but its there. The big advantage of the 75 has already been pointed out--the 0.7m close focus distance. It's a great lens on the M8 or M9, and one of my favorites.
Yes, Daniel Kennedy has it right. If you Google the two words, reproduction ratio, you will get better definitions than I can provide.
I also think the IQ is better on the 75, but not all agree. In addition, the 75 cron is quite small for the amount of punch it provides- especially as compared to the 90 AA.
The reproduction ratio is the size ratio of image-to-subject. 1:100 means that (e.g.) a 1m size object is 1cm large on the sensor or film (1000mm : 10mm = 100). 1:1 means same size.
The 90mm summmicron, like nearly all Leica 90mm lenses, focuses to 1m and has a maximum reproduction ratio of 1:8.9.
The 75mm Summicron focuses to 0.7m and has a maximum reproduction ratio of 1:7.
But a 50mm lens that also focuses to 0.7m has a max repro ratio of c. 1:12. Tyros often believe thast the important thing is how close you can get. But reproduction ratio is a function of BOTH close focus limit AND focal length. An 18mm lens that can focus to 0.5m has a maximum reproduction ratio of c. 1:23! That is what the 75mm Summicron does at a little less than 3 meters.
The old man from the Age of Guess Focus
I have both and they are very good lenses. They're both so good that I would choose based on focal length preference and ergonomics.
The 75 is much smaller than the 90 (and my 90 is black paint so it's heavier than a normal black chrome model). The 75 focuses closer as others have mentioned.
Personally, I like the 90mm framelines better since I find them easier to use than the corner-mark 75mm framelines. Also, and this may be sample variation, but my 90 has a much smoother focusing action than my 75. I don't know if it's because it's a brass lens or just the lens design, but my 90 has the smoothest, best feeling focusing of all of the Leica lenses I've used.
Size is a big issue for me though, since I travel a lot. I plan to sell one of these lenses soon, since I rarely use a long lens. (On my last project out of around 4K frames I think I used the 90 for about 50 and one or two made the final edit.) Since I don't use it much, keeping the 75 is very tempting since it's very compact. Though I may decide to sell the 75 and get a 90 Tele-Elmarit for travel and keep the 90 'Cron for assignment work where I may need the lens speed.
Both lenses are very sharp even wide open, and I don't personally find the 90 to be harsh at all.
IMO, the 75mm framelines are improved on the M9. Now there is more than the corners-mark.
Lucien
I haven't noticed much difference, the corner marks on the M9 are still pretty small, though admittedly if they were larger they might be distracting when using the 50mm frames.
Anyway, it's a matter of opinion, but it's something worth thinking about since the focal lengths are pretty close and both lenses are excellent so small differences in usability could be the deciding factor.
