Which 90mm lens for an M8?
photolandscape
The full term is "infrared cut filter", and it is a normal screw-in filter with red cast when viewed from the side, which just removes all or most of the infrared in the incoming light. One example is the B+W 486 UV/IR filter.
Just a quick clarification. The filter is clear. It may show a red cast when viewed from certain angles *if* it is reflecting a noticeable amount of IR.
Cheers,
Sean
I had both the 90 APO-Summicron and the Tele-Elmarit, the so-called "thin" version. But I also bought the 75 APO-Summicron as soon as it was announced. Both Summicrons are superb. When I found out that the M8 would have a 1.33x lens factor, I promptly listed and sold the 90 Summicron figuring that the 75mm would take its place. Anyway, I needed the cash from the sale of the 90 for the buy of the M8 anyway.
My former "long" tele was a much-loved 135mm Tele-Elmar (also sold to provide cash for the M8 buy). It has a maximum aperture of 4.0. The 90mm T-E when boosted by 1.33 becomes a 120mm lens, now my "long" Tele for the M8. So, in the exchange of my long tele lenses on the M8, I effectively gained an f-stop.
I've never been disappointed by the images my 90 T-E delivers but I would never argue that any 90mm Summicron beats it. For as much as I'll use the "120mm" format on the M8, the 90 T-E suits my purposes just fine. I do miss that 135 Tele-Elmar though so maybe there's a Hektor in my future that would let me mess around with the M8's "180mm format."
-g
The second version of the 135mm f/2.8 (with glasses) is also meant to be quite good. The first edition is almost the same, except a little less flare resistance wide open. I have such a lens on the way, but I have only tried it on my M8 in the store so far. It seems quite possible to focus, especially with the 1.25x loupe.
A 90 Elmar-C is an excellent lens and is quite affordable if you can live with f4. Erwin rates it just behid the current Elmarit as far as optical quality is concerned. I have both and take the Elmar-C when I want to keep the size and weight down. Shots of it and from using it here: Leica Elmar-C 90mm 1:4 Photo Gallery by Carl Bretteville at pbase.com
- Carl
As with grober, when I need a "zuper-tele" the 90/2,8 T-E "thin" does very well, for me. Long ago I had the 90/4 Elmarit(sliding hood), but was having to much fun with other lenses and sold it towards purchase of a second M body. Bought a T-E used later on...
...your query prompted me to don the T-E and snap this, attached. Souped with VueScan: no profile, no WB, no sharpening... just read in the DNG and output the JPEG you have here. I did use a B+W 486 filter... and no hood(!).
BTW, do you mean 90 lens, or near equivalent with an M8? If you seek pictures with a 90 FL, then I'd agree with the suggestion of the 75/1,4(michael_b_elmer)
rgds,
Dave(who's just getting used to this M8 before it goes back to Solms for correction)
