M8 recognizes uncoded Tele-Elmarit !
colorflow
This is interesting. I just bought a 90mm fat tele-elmarit which is of course uncoded. But my M8.2 knows it is a 90mm lens and the exif even knows it is the "tele-elmarit type II". The code for that lens is 000100 which is just one black mark with the rest all white. Looks like there is a screw head about where the black bit is supposed to be. I guess it is being read as a black bit and the chrome being read as white.
This has been reported before. I've had something similar with a Voigtlander 90mm lens. I was using it with an adaptor that had a cut out near the code sensor. A few shots were recorded as a 24mm Elmarit.
That as clever way to have a "lens-upgrade"...;)
I might point out that the "fat" Tele-Elmarit was the FIRST version - the "Tele-Elmarit type II" is the thin version, so your M8 is recognizing the "wrong" lens....
not that it matters - the corrections needed (probably zero) would be about the same regardless. And, yes, it is a screw head that acts as a "black pit" to simulate the coding.
My M8s were promiscuous - they'd recognize anything with a 28/90 mount as a Tele-Elmarit 90 type II, including my v. 4 28mm and my 90 Summicron, thanks to the screw head (and in the absence of real coding).
Luigi:
Mine is 2489663. If you place the mounting slot at 12 o'clock, there is a screw between the 4 and 5 o'clock position (closer to 4 than 5). That must be the screw my M8.2 is reading. It is not dirty, but seems not to reflect as much light.
I always like to have the opportunity to use my DR Summicron... :)
This is the back of my lens, the evidenced screw is the one you spoke of, that is inside the bit-reading stripe... my guess is that, being the screw's head cut almost "horizontal", the "black area" is too small to trigger the bit sensor.
