photophile Posted November 13, 2009 Share #1 Posted November 13, 2009 Advertisement (gone after registration) I am sure I have seen this before - but my m8 just returned from NJ for some adjustments - and now the frame counter says 999xxxx. When it left, the last images were 101xxx. I put the memory card into the camera with the 101xxx pics on it - but it did not reset. I'm sure there is an easy menu setting.. but I can't find it. Any advice. I'd hate to have to start at the 999xxx number as it will really mess up my image bank retreival sequence system ( my own filing method). Many thanks. Coos Link to post Share on other sites More sharing options...
Advertisement Posted November 13, 2009 Posted November 13, 2009 Hi photophile, Take a look here help needed to reset counter after repair. I'm sure you'll find what you were looking for!
jlp Posted November 14, 2009 Share #2 Posted November 14, 2009 try this from previous post. . . link and then post #20 Link to post Share on other sites More sharing options...
photophile Posted November 14, 2009 Author Share #3 Posted November 14, 2009 when I follow this recipe - and replace the card after the rename - it says "no valid image to display" even though it appears on my computer correctly. When I take the following image - it goes back to zero. There must be another step somewhere? Link to post Share on other sites More sharing options...
photophile Posted November 14, 2009 Author Share #4 Posted November 14, 2009 JLP - thank you for the link. After I went back in, I realized I did not change the master file number in the DCIM folder first - and then reset the sub-folder with my preferred number. Worked like a charm once I did that. Thanks again. Best. C. Link to post Share on other sites More sharing options...
